Old 01-20-2014, 11:55 AM   #1
brownkid72
2001 Chevy z71 starts but doesn't run need help diagnosing problem
I have a 2001 Z71 with a 5.3L and last night I was going to the gas station and I started my pick up and it ran no problem for a couple of seconds, and then it started sputtering like it was running out of fuel. Walked to the gas station got two gallons of fuel, and tried starting it and it would start run fine for a couple of seconds and then start running rough then die. I then put two more gallons of fuel in the tank and tried again, same scenario would happen. I at checked to see if I had fuel at the engine and it did.
When I put fuel in it the first time I heard the pump start up when key was turned on engine off, and every time the key was on and shut off when it was at pressure ( I assume) I was unable to check fuel pressure where I was at last night.
My question is what could be causing this issue of not running?
brownkid72 is offline   Reply With Quote
Old 01-20-2014, 12:59 PM   #2
Jmiller022
Jmiller022's Avatar
Re: 2001 Chevy z71 starts but doesn't run need help diagnosing problem
those pumps don't like to be ran out of gas, the use the gas for cooling so when you run them low a lot it can cause them to go out.
Also you can have pressure at the engine and it not be enough to run properly, you need to put a gauge on it.
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 01-25-2014, 11:59 PM   #3
57chevyman
57chevyman's Avatar
will it keep running if you hit the gas? if you have a loose battery connection, your computer could "forget" the idle speed
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 01-28-2014, 06:28 PM   #4
structures
structures's Avatar
Sounds like the fuel filter. I seem to have to put one of those in every 50k.
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 01-28-2014, 09:45 PM   #5
Boog
laying low
Boog's Avatar
Check the fuel pressure before anything else. always.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
