Old 12-22-2003, 11:55 AM   #1
Larry68GMC
WTB: Edelbrock\Holley 750 carb
Anyone got one? Prefer manual choke...thanks
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1
RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall
'05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD
Larry68GMC is offline   Reply With Quote
Old 12-22-2003, 12:12 PM   #2
J.Lance
Too many is never enough!
Edelbrock
I have a Edelbrock performer 750 that needs gone through. If I remember right, it is an electric choke. It was on a motor I bought that had been sitting for quite a while and has some crust on the internals of the carb. I'd take $50 plus the ride if you are interested.
Also have a Holley single pump, 1978 L82 replacement carb. Not sure of the CFM but I think it is 600, electric choke. Ran good on a motor I had but had been sitting previously and was leaking fuel out of the tube that connects the front and rear bowls. I ended up throwing on a different carb and shelved it. Only had about 3000 miles on the carb when I got it. Also it is a spread bore. I take $50 for that one too.
Jason
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
Old 12-22-2003, 12:23 PM   #3
Larry68GMC
Can you post some pics of the Edelbrock? Thanks
Old 12-22-2003, 12:26 PM   #4
J.Lance
carb
I can certainly do that but won't be until later this evening after I get back from work.
Jason
1971 K2500 GMC LWB
Old 12-22-2003, 12:28 PM   #5
Larry68GMC
Ok sounds good..
Old 12-22-2003, 11:57 PM   #6
J.Lance
carb
My apologies, it is actually a Carter AFB. I ran the numbers in the Carter book a while back and it is a 750. I needed a 600 so I didn't use it. The part number is 9755S 0185.
Jason
1971 K2500 GMC LWB
Old 12-23-2003, 12:38 AM   #7
breeh
Recovering 67-72 Addict
breeh's Avatar
I've got a 750 Holley Musclecar replacement. It is on my 427 now and works great. Unfortunately, it is not the best carb for a 4x4. It doesn't like being tipped over 40 degrees. I was running it on my Camaro before it went on the truck. It does have an electric choke though. If interested, I will take $100.00 plus the ride. It cost me over 400.00 new.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 12-23-2003, 02:04 AM   #8
Larry68GMC
breeh, can you get some pics of that carb or the numbers?..thanks.....Larry
Old 12-23-2003, 02:10 AM   #9
Larry68GMC
Lance...PM sent.
Old 12-24-2003, 05:37 PM   #10
breeh
breeh's Avatar
Here are the pics. The numbers that are on the choke horn are:
80509
1085
Old 12-24-2003, 05:38 PM   #11
breeh
breeh's Avatar
The Holley site says this is an 830 CFM but when I purchased it from Summit it was advertised as a 750 CFM. Go figure??
Old 12-26-2003, 05:21 PM   #12
breeh
breeh's Avatar
TTT
Old 12-27-2003, 03:08 AM   #13
truckpower429
Dang Larry if i knew that you were needing one ..i have and extra edelbrock 750 cfm ..pm me or email me and if interested ..let me know..we might be able to work something out ... Willie
truckpower429 is offline   Reply With Quote
Old 12-27-2003, 02:14 PM   #14
danho
Pesemistic Optimist
danho's Avatar
http://www.pirate4x4.com/forum/showt...hreadid=171206
HTH.
Dan.
danho is offline   Reply With Quote
Old 01-04-2004, 11:42 PM   #15
1972C10
1972C10's Avatar
Ive got a milled down 750 holler No choke. 150$
1972C10 is offline   Reply With Quote
