Old 01-23-2014, 04:21 AM   #1
Andy4639
Old member
Andy4639's Avatar
Question New question
When I get the stock 6.0 Dino tuned by Hawks can I get it where it has a run and tow mode tune? I know I read some threads about this but forgot where. If it was here are over on the LS1 site. Would it be worth it to get it done if possible?
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-23-2014, 09:32 AM   #2
Custom 68
Custom 68's Avatar
Re: New question
you should talk to them Andy but I think the only difference is the shift points so no I wouldn't mess with it. Some hoped you could change the timing and other "performance" settings and change it according to fuel but that does not appear to be the case.
They should have a sheet for you to fill out since yours is stock the main question will be what fuel are you going to run. That will dictate how aggressive the tune will be.
good luck and hope it is running tomorrow for you.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 01-23-2014, 11:25 AM   #3
ls1nova71
ls1nova71's Avatar
Re: New question
It was probably here that you saw it. It's a wire added to the PCM, a switch and some tuning. I have it on my truck but rarely use it. http://67-72chevytrucks.com/vboard/s...d.php?t=607563 I
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-23-2014, 03:59 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: New question
Yes that was it. I couldn't find it last night. Must have been half asleep!
Well I guess I will run regular pump gas!
Waiting on Bruce to call me back now. Doesn't look good for tomorrow. Tuesday he called looking for the clutch info I had on it. He was going and try that route. We will see!
