Old 01-24-2014, 07:54 AM   #1
luvbowties
luvbowties's Avatar
Smile What stall speed to use?
I'm having a new 700R4 built, as present one has 'high-mileage leaks & looseness'. Going with a mild shift kit, one my reputable, local guy says will shift soft enough in normal driving and harder with increasing throttle. Using ~27-inch tires and a 3.73 differential--and this has been a quite satisfactory combo for 2-3 years.
Tranny man asked me what stall speed convertor--lockup type, of course--I wanted to go with. There will be no 1/4-mile runs and mostly around-town driving; maybe 1 @ 150-mile trip a year. Engine is stock 96-97(?) 5.7 vortec with 4bbl intake and carb and headers. And I DO use the lockup, planning to do the same w/new tranny as present one:locks up when it shifts into overdrive, yet I have a lockout switch run under dash to completely bypass the lock-up when I desire.
Knowing practically zilch(zero)about stall speed convertors, and never driven one for any length of time, I need to ask which one to go with. He says he'd rather me specify this parameter, altho' he's calling all the other shots AFTER learning how I drive and what I want to do with my truck.
Thanks,
Sam
luvbowties is offline   Reply With Quote
Old 01-24-2014, 08:01 AM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: What stall speed to use?
In my opinion, a 2500 would work just fine since it's a cruiser.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 01-24-2014, 08:32 AM   #3
wjjeeper
wjjeeper's Avatar
Sounds like you are in the exact boat as me regarding driving style, up level etc.
In my 700r4 I put the lockup switch and have a 2500 rpm stall.
I'm very happy with the set up.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 01-24-2014, 10:47 AM   #4
davbowen
davbowen's Avatar
since engine is stock and assume the tranny is stock. use a stock converter what ever that may be.
davbowen is offline   Reply With Quote
Old 01-24-2014, 11:05 AM   #5
racecougar
racecougar's Avatar
A 2400-2800 rpm stall should be right on the money for a stock 5.7L Vortec.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 01-24-2014, 11:11 AM   #6
Rich 5150 69
Rich 5150 69's Avatar
If it were me, I`d run the BM hole shot its only 2100 first stall above stock, it will generate less heat, out side of OD, lower rpm drivibity will be better on the fuel.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-24-2014, 04:50 PM   #7
neal 66
whats wrong with a stock one? engine is stock,3 73s are going to get you movin quite easy.i have 700r4 3 73s 305 and 285 70s and can smolder tires with ease if I choose.my truck is soon to have 5.7 vortec with cam and will still have stock converter.by 305 I mean chev. not gmc v6
neal 66 is offline   Reply With Quote
Old 01-24-2014, 07:40 PM   #8
boucher racing
boucher racing's Avatar
I am getting ready to do a T5 to 700r4 swap in my 66.
After way to much brain racking, I decided to go with a FTI street brawler 2400 lock up torque converter. I heard/read many good things about FTI and the price was on budget.
My set up is:
-3.54 rear gear
- 29" tires
- turbocharged inline 250
What are you running for a trans cooler?
Boucher'
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 01-24-2014, 07:44 PM   #9
jayoldschool
Moderator
Lowest stall, stock converter you can find. I would suggest one from a Caprice/Roadmaster/Fleetwood. 1800ish.
jayoldschool is offline   Reply With Quote
Old 01-24-2014, 08:46 PM   #10
Sharps40
Originally Posted by jayoldschool View Post
lowest stall, stock converter you can find. I would suggest one from a caprice/roadmaster/fleetwood. 1800ish.
+1
Sharps40 is offline   Reply With Quote
Old 01-24-2014, 09:41 PM   #11
HumphreyMurdoch
HumphreyMurdoch's Avatar
I was always told to keep it below your cruising RPM on the highway. maintaining RPM below stall speed causes it to constantly slip and will burn your transmission up.
HumphreyMurdoch is offline   Reply With Quote
Old 01-24-2014, 09:48 PM   #12
bama63
bama63's Avatar
Originally Posted by sharps40 View Post
+1
+2
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 01-24-2014, 09:58 PM   #13
racecougar
racecougar's Avatar
That's a good idea if you're using a non-lockup TC. With a lockup TC, that becomes a non-issue.
