Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-25-2014, 12:26 PM   #1
oletimer72
oletimer72's Avatar
cs130 alt in a 72 c10
ok..guys I have a 72 c10 with all the brackets and pullys from a 94 chevy..and a new American autowire harness but cant get my alternater to work...everything is new alt,batt belts...how do these wires hook up...thanks
oletimer72 is offline   Reply With Quote
Old 01-25-2014, 06:10 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: cs130 alt in a 72 c10
Is you new AA harness completely stock or has it been upgraded to the CS alternator.
Look at the harness near the large red wire for the alternator and check the plug that goes into the alternator.
This is a good thread for the conversion but it starts out for the SI style alternator and goes on to the CS style. Check the link I posted for the CS conversion and also read the whole thread. if you don't follow any of it just post back and I'll help you out.
........ http://67-72chevytrucks.com/vboard/s...d.php?t=320787
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-25-2014, 08:34 PM   #3
oletimer72
oletimer72's Avatar
I read the whole thread but still don't get it...and I have the American autowire 510089 classic updated kit...thanks for your help
Old 01-25-2014, 09:08 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
You have a battery stud that comes out the back or the alt. it goes to the battery or starter stud with a fusible link in it. You have a red wire coming out of the alt plug. connect it to the battery wire about 18" to 24" back into the wire. You have a brown wire coming from the ignition connect it to the "L" wire on the plug.
Old 01-25-2014, 09:52 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
OK answer these questions for me and we'll get started.
1. Do you have the external voltage regulator with the four wire plug that's mounted on the left radiator support?
2. Which alternator do you have. Is it the 72 or the one from the 94.
Name:  1964--66 chevy truck help pictures 018.jpg
3. Do you have the idiot light dash or the charging gauge dash?
Name:  dash gauge.JPG
VetteVet
Old 01-25-2014, 10:31 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Attachment 1205786
Attachment 1205765
Attachment 1205767
Attachment 1205784
The kit he has doesn't have the wiring for a DN alt or an external regulator He has the update kit and it has wiring for SI and CS alt's
Old 01-25-2014, 11:17 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Thanks Dave, now if we can just find out what he does have we can fix him up.
Do you know if the kit has HEI wiring and the headlight relay mod?
His subject line says CS 130 so I guess that's it.
VetteVet
Old 01-25-2014, 11:22 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Dave, you got any ideas on this one.
......http://67-72chevytrucks.com/vboard/s...d.php?t=613632
VetteVet
Old 01-25-2014, 11:56 PM   #9
oletimer72
oletimer72's Avatar
ok....1 no external regulater 2, 94 alternater ,3,,charging gauge dash...thanks vettvet
Old 01-26-2014, 12:30 AM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Ok that's why I asked about the wiring harness and the wires for the alternator.
If you want your battery gauge to work in the dash then wire it just like this picture. Your harness may not be setup like this diagram. in fact it may not even have the two small 18 gauge black wires and the fuses that the gauge requires.
If you can find the 16 gauge brown wire that comes from the bulkhead connector to the alternator, it should have the resistor in it and it should be in the alternator plug connected to the L terminal on the alternator. The other wire
is the red 12 gauge wire for the S terminal and the large wire is probably a 10 gauge red wire that connects to the back of the alternator.
Name:  Alternator Pinout.jpg
VetteVet
Old 01-26-2014, 05:36 PM   #11
oletimer72
oletimer72's Avatar
vettevet took youre information and went to work...you solved all my problems ...thank you very much....awesome people on this board !!!!
Old 01-26-2014, 05:58 PM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
That's great!!!! now if the Bronco's can only win the super bowl.
VetteVet
