Old 01-25-2014, 06:53 PM   #1
Thomashsturgill
My CLR experience... so far.
My new truck had a hazy grey look that I thought was just oxidized paint (originally Med. Olive) but as I CLR'd it today I realized it might just be some sort of rattle can layer but I'm pretty pleased with the patina and the look I'm getting. Its been a lot of work (elbow grease).
I'm using 50/50 CLR to Water. Any other advice from other member's experience with this? I'm hoping to clear coat in the future.
Thomashsturgill is offline   Reply With Quote
Old 01-25-2014, 07:01 PM   #2
Thomashsturgill
Re: My CLR experience... so far.
I'm having trouble gettin' my pictures to upload right. Sorry
Old 01-25-2014, 07:12 PM   #3
71swb4x4
71swb4x4's Avatar
I am no CLR expert. In my opinion the hazy part you are taking off is oxidized paint. The green pad is taking off that last little bit of original paint that was left over the original primer in those thin spots. It looks like you may be rubbing a little hard. The pressure points (corners) seem to be taking the brunt of the pad.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-25-2014, 07:24 PM   #4
Thomashsturgill
I might be but I will say that a lot of the metal showed up with no effort...just sitting right under the oxidized paint.
Old 01-25-2014, 07:32 PM   #5
71swb4x4
71swb4x4's Avatar
I am no expert, and you are the one doing the work, so I am sure you are right. You just have very thin paint in those places.
Old 01-25-2014, 07:33 PM   #6
tommys72
tommys72's Avatar
You might be rubbing hard (im no expert) but I like it
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 01-25-2014, 08:14 PM   #7
terry b
terry b's Avatar
so how will you keep it from rusting now that you removed the last of the paint?
terry b is offline   Reply With Quote
Old 01-25-2014, 08:28 PM   #8
hopped up
hopped up's Avatar
I say use a finer scuff pad
hopped up is offline   Reply With Quote
Old 01-25-2014, 08:32 PM   #9
Grumpy old man
Grumpy old man's Avatar
I'm getting too old if someone got anywhere near my trucks with CLR they would have a serious problem !
Old 01-25-2014, 08:46 PM   #10
68basket
hate to say it also, but it looks like you are using the wrong scuff pad or rubbing way too hard, especially on the edges.
68basket is offline   Reply With Quote
Old 01-25-2014, 08:52 PM   #11
Tinkermc
you could be rubbing a bit hard since there is very little paint left and you said it was a lot of energy.
Tinkermc is offline   Reply With Quote
Old 01-26-2014, 10:15 AM   #12
richards72chevy
richards72chevy's Avatar
Maybe just fine rubbing compound will do the trick.
richards72chevy is offline   Reply With Quote
Old 01-26-2014, 12:08 PM   #13
too much stuff
Roadtrip!
too much stuff's Avatar
You took the original paint off. Bascially it looks like you are sanding for a new paint job. The bare metal will need primer/paint over it now. And remember, primer is not much good without paint over it.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-26-2014, 01:20 PM   #14
tmc1986
I think it looks good. keep doing whatever you are doing.
'67 2wd LWB 350/4speed.
tmc1986 is offline   Reply With Quote
Old 01-26-2014, 06:05 PM   #15
Thomashsturgill
Ok so day 2.
I think you guys are right and I was scrubbing a little too hard. I was trying to get all the grey oxidized paint off but didn't know my own strength. The original paint underneath was so pretty (but thin). Today I was a little more delicate and was mindful of the corners. There are still places, mostly in the back half and not pictured, where the paint just gave up and came off with no effort.
I also tried a number of other things including rubbing compound and using a rag instead of scothbright pad. None seemed to work well/better.
I still like the way it looks and wonder is a clear coat will preserve it for at least a while.
Old 01-26-2014, 09:31 PM   #16
Thomashsturgill
Thats going to be a good question...maybe get original matching top coat color and do a few touchups. I'll have to cross that bridge sooner than later.
Old 01-26-2014, 09:35 PM   #17
terry b
terry b's Avatar
What about rattel can clear coat? Might buy a year or two maybe more if you keep up with it.
Old 01-27-2014, 12:30 AM   #18
Cape Codder
Cape Codder's Avatar
I would sand and paint the truck correctly, but I am not a patina guy. Anything you put on that doesn't seal it is a waste of time and if you just clear it that will all have to come off when you do decide to fix the problem ,and it will turn into a problem unless you keep it out of bad weather.
Cape Codder is offline   Reply With Quote
