01-20-2014, 09:06 PM | #401 |
Re: Project 69SWB
I got started on the steering wheel this weekend, need to let it cure for a couple days before I start sanding on it.
I dug out all the cracks, my Dremel battery bit the dust, so I had to improvise with my die grinder and rasp files. Slowly filling back in... it's hard to get it just right That's put away to cure and then the real fun will begin... |
01-20-2014, 09:12 PM | #402 |
Re: Project 69SWB
Meanwhile, back in the garage, it was finally warm enough and I had the time to finish the last bit of metal work and get my doors in primer.
My door painting apparatus.. bailing wire is for backup, it's screwed together. I'll come back once this dries and touch up the spots where the hooks touch. I got this idea from JMKING (thanks bud) but I didn't want to hang them from my garage door racks so I could close it down when I was done. When I actually spray the color coat I'm going to have to get a longer board, too close to ladder for that, but worked fine for primer. Black Epoxy PPG JP377 Followed by Grey Epoxy JP205 |
01-21-2014, 01:56 PM | #403 |
Re: Project 69SWB
I like your door shootin' rig! I'll be stealing that one.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-21-2014, 03:54 PM | #404 |
Re: Project 69SWB
One of my many contributions to society.
01-21-2014, 05:17 PM | #405 |
Still Learning
Re: Project 69SWB
Very nice work on the doors and steering wheel Jimmy! That gray epoxy is high build sandable primer?
I have been playing with my doors lately too. |
01-21-2014, 05:35 PM | #406 |
Re: Project 69SWB
Yessir it is high build sandable. I've got everything except the bed (saving it for last) now done this way. Gonna fit and fit, then do any filler work, glazing and blocking.
01-21-2014, 05:40 PM | #407 |
Re: Project 69SWB
Nice job on the doors Jimmy, are you spraying in your garage and is it attached to your house. Mine is and more specifically it's attached to my kitchen. Just wanting to know how the fumes are. I don't know what to do for mine.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-21-2014, 06:33 PM | #408 |
Re: Project 69SWB
I like the way you hung the door to paint them. it will work.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
01-21-2014, 11:02 PM | #409 | |
Re: Project 69SWB
Thanks George, I'll have to get a longer board to get out and away from the ladder a tad for when I lay the color, was kind hard spraying around that close to the ladder... worked fine for the primer though. |
01-21-2014, 11:39 PM | #410 |
Re: Project 69SWB
I bought some of that PC-7 for a wheel fix planned in the near future. How long can you mess with it before it gets too hard?
And your doors look killer along with the ladder set up. Great progress |
01-22-2014, 06:19 PM | #411 |
Re: Project 69SWB
Thanks! Says remains workable for 1 hour at 70deg on the can. I messed with it for a good 30 minutes and it was still pretty gooey. Even went and checked on it after a couple hours and it was still tacky and soft but I don't think I could have molded it at that point. I did this all in the house so it was about 68degree-ish
01-26-2014, 07:54 PM | #412 |
Re: Project 69SWB
I was going to work on the steering wheel resto this weekend, but I couldn't wait to get the doors back on and start lining this truck up... so I worked on putting the doors and fenders on this weekend so I can do final body work...
The doors are lined up and shutting great using GMCpauls door seals.. They're top notch. I put those on so the doors will be just where I want them as I'm working. I also rolled it out into the sunshine (it's been a while). after body work I get to take it all apart again to paint it. I still need to fit the fenders better, but the doors are shutting and fitting great. I was losing sunshine in the driveway and wanting to get some good pics so I had to stop and roll it out. Cold weather returns tomorrow. :-/ Obligatory favorite modes of transportation bff shot and all tucked back into the garage.. time to get serious on body panel alignment. |
01-26-2014, 08:05 PM | #413 |
Re: Project 69SWB
Doors are looking awesome Jimmy, they look super smooth. You did a excellent job on them.
Scott |
01-26-2014, 08:33 PM | #414 |
Re: Project 69SWB
Nice job Jimmy she's looking good
01-26-2014, 09:20 PM | #415 |
Still Learning
Re: Project 69SWB
Awesome progress on the doors and fenders. I took advantage of that nice weather myself. Back to arctic tomorrow ...
01-26-2014, 10:31 PM | #416 |
Re: Project 69SWB
Looks great man! How's your motivation level after seeing it sitting outside like that? A 10? I pushed my cj7 outside today to wet sand the high build, and something about seeing sitting outside again, lit the fire. Anyway, your truck is gonna look awesome when you get that black on!
1970 SWB Build |
01-26-2014, 10:53 PM | #417 |
Re: Project 69SWB
Sweet! Coming together nicely!
01-26-2014, 10:58 PM | #418 | |||
Re: Project 69SWB
Thanks Keith... Still get a long way to go but I'm happy so far. Quote:
You're making me want to build another jeep with that jeep talk. Here's my last one. I sold it though. :-( Here my last jeep fresh out of the garage. http://ozarksjeepthing.com/c/index.p....html#msg56305 And out in the trails during its shakedown run. http://ozarksjeepthing.com/c/index.p....html#msg56311 Those are deep links to my build thread on that site if you ever get bored check it out... I did a ton of fabricating on that jeep. 1 ton axles, 40" pit bull rockers, locked front and rear, twin stick too. Last edited by ~Whitey~; 01-26-2014 at 11:53 PM. |
01-26-2014, 11:52 PM | #419 |
Re: Project 69SWB
01-27-2014, 09:27 AM | #420 |
Re: Project 69SWB
Nice and straight in prime! That's the bad part, you just wanna slap 'em the rest of the way together and go!
01-27-2014, 10:18 AM | #421 |
Re: Project 69SWB
Oh do I know. The thought did cross my mind, but I've got a little filler work to do, some glazing, and lots of blocking. I want this thing to be straight! I'm working with all original metal here... save for the rockers, inner cab supports, and cab corners.
01-27-2014, 12:34 PM | #422 |
Re: Project 69SWB
Looking good!
"its not a hobby, It's a Lifestyle" . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
01-27-2014, 07:17 PM | #423 |
Re: Project 69SWB
Thanks a bunch. Checked out your thread. Super mad skills man! |
02-01-2014, 01:12 AM | #424 |
Rusty Nuts
Re: Project 69SWB
Jimmy just got through the rest of your build. You have came along way since I last seen it. Looks really good. Now get it done so we can cruse in them this summer.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
02-01-2014, 09:40 PM | #425 |
Re: Project 69SWB
Wow you've made some progress ! Nice job man,.. keep at it.
Tags |
1969, black, custom 10, fleetside, shortbed |
