12-23-2003, 01:23 AM | #1 |
Oh,you can't buy that new
headers for lowered trucks. what works?
Since the headers on this 81 are mangled on the bottom beyond repair I have decided to replace them. I thought someone here had said that Chevelle headers work and sit up higher ? has anyone really tried this ?
I need full length headers not shortys. any recommendations thanx , DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
12-23-2003, 01:25 AM | #2 |
Hotwheels?
My thorleys are full length and have no clearance problems whatsoever, Ive never scraped them once.
4/6 too.
1978 Money Pit - CUSTOM DELUXE!!!! |
12-23-2003, 02:10 AM | #3 | |
12-23-2003, 02:20 AM | #4 |
I have hedmen full length headers with a 4/6 drop. I dont have any problem with clearance or bottoming out.
12-23-2003, 02:33 AM | #5 | |
Garage Queen Material
12-23-2003, 03:04 AM | #6 | |
Hotwheels?
12-23-2003, 03:24 AM | #7 |
the Cyclone full lengths that were on my lowered truck when I bought were scrappin all the time. with a big block I couldnt find much to choose from. I bought Sanderson Shortys.
75 GMC C-15 short/step factory 454, lowered |
12-23-2003, 08:52 AM | #8 |
yeller
Hooker Competition full length headers on a 4/4 dropped SBC equipped truck...never hit once in 4 years of driving.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
12-23-2003, 10:40 AM | #9 |
Last time I check prices on Thorleys they were $400+. The chevelle 3/4 length from Headman or Hooker will work & be cheaper. The downside is Thorleys are a 2 into 1 configuration so you gain torque over the un-equal length of the 3/4 style.
12-23-2003, 11:52 AM | #10 |
Hookers here and they scrape like mad
12-23-2003, 12:30 PM | #11 |
with the 4-6 (or 5-7, not sure) drop thats on this truck it doesn't even have collectors anymore. they are hedmen full lengths.
Timspeed- when you say 'G' body you actually meant 78-88 body style right?? the 73-77 chevelle was still called an 'A' body I believe. I know all the major header manuf. list the 78-88 seperately. More importantly can anyone verify that this 78-88 header works out?? I need to get these collectors up . there is a good 4" of clearance between them and the floor now so i know i have room to bring them up. Even without the collectors they give me trouble on my trailer ramps. thanx for all the input guys keep it coming. DAVE
12-23-2003, 03:26 PM | #12 |
I have a 4/6 drop(maybe not) with hedmen full length. I have about 4" of clearance. I dont go over speed bumps very fast . Or go up sloped driveways very fast . One thing I did was rotate the flange so I have the most possible clearance. I also have headerhush power flanges or flange stifners to keep from tearing up the weak flanges.
12-23-2003, 03:45 PM | #13 |
the headers i'm using that timspeed is talking about are for late 60's early 70's camaros and chevelles. they are NOT full length. if you try to use a full length car header on your truck the collectors are most likeley going to shoot straight into the tranny crossmember. this is what matt (82 blackbeast) did on his truck. he then had to build a custom tranny cross member to clear the headers as well as clearence the frame for the large diameter camaro full lengths he is using. if you really think you need full lengths and go the car header route you are just going to have to shoot in the dark and mabey you will get lucky. the short headers i'm using WILL fit with no modifications. the are very small primary tubes and 2-1/2 collectors, but will work fine for anything producing less than about 350 hp. they are really choking my 408, but i had planned to go the same route as matt if i wasn't going back to a stock motor. i've listed the part number for my headers before but i don't have it handy right now, just do a search if you want it.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
12-23-2003, 03:54 PM | #14 |
thats about 3.5" of clearance |
12-23-2003, 04:21 PM | #15 |
I didnt find that a problem the crossmember being in the way. I just went right over the top. I made my own exhaust system. I guess if a guy doesnt own a welding machine this would be a big problem. I dont own a tubing bender neither. iIjust make minor cuts and weld it all together. this does hurt your flow having restriction in your pipe. I run 2.5" exhaust system its plenty big (sbc) to make up for any losses. I can weld alot better then them guys down at the muffler shop. A guy could just as easy make his own dual crossmember.
12-23-2003, 05:12 PM | #16 |
. they are really choking my 408, but i had planned to go the same route as matt if i wasn't going back to a stock motor. i've listed the part number for my headers before but i don't have it handy right now, just do a search if you want it. [/B][/QUOTE] I'm not going to choke mine down. what I'm trying to find out is what full size car application did 82 blackbeast use . I most likely will not have the crossmember problems because mine is way back with the 400 trans. I can also build my own x-member if needed. thanx , DAVE
12-23-2003, 08:24 PM | #17 |
I can't speak for trucks with small blocks anymore. The headers I have now are hooker #2455 and they tuck up between the framerails. I also use a double-hump crossmember and it works great. If I were you Dave I would order the Hooker #2451 from summit and if you had any trouble with fitment just send them back and eat the shipping...no biggy! They should fit between the framerails. Good luck!
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
12-23-2003, 08:52 PM | #18 | |
Jay , sure rub in the big block thing now. I really wanted to get together with you and your other truck buds over the holidays ,but it looks as if it's going to be a while now because of the royal F@^#%ng this A-hole gave me on this truck. I WILL prevail, but there are SO MANY jury rigs(the headers just being one of MANY!) on this truck it will most likely be spring before i can come see ya. I know there are a lot of swap/cruises your way and I shall get there,but in the mean time if you are ever headed to the track be sure to let me know , DAVE
12-23-2003, 09:44 PM | #19 | |
12-24-2003, 02:49 AM | #20 |
jeremy nailed it, those are the ones matt is using but they are too big for anything less than 400-450 hp. i think matts 406 is making over 500 so thats why he used them. with some 1-5/8 headers the frame rails might not need clearencing like he had to do on his.
12-24-2003, 02:58 AM | #21 |
ryan, would those shorties you have handle <400hp pretty well?
12-24-2003, 03:02 AM | #22 |
the ruined headers on it now are husslers( i found the tag). Yes 1-5/8 is the minimum I will take as it does have the 1-3/4 now and yes it is ,and always will be, in the 450-up range for HP. DAVE
01-02-2004, 03:36 AM | #23 |
GEt some flowtechs for 88-98 the direct fit you will have to get pipes run to them with the flare type flange but they are a real good shorty style header with 3/8 thick flange.
