Old 01-28-2014, 01:15 AM   #1
LBJ
77 Chevy - Fix for Broken Glove Box Hinge?
My glove box door is about to drop off due to the plastic door hinge wearing smooth out. Parts vendors want $50 for a new plastic insert. Anyone fixed theirs without that much money outlay? Will a piano hinge from the hardware store work? I must admit, I haven't eyeballed it too close other than to see it's about to fall off completely.
Been a while since I posted here. Good to be back. Lots been going on I am sure. Chevy trucks are more popular than ever. I did some work to mine recently. Added the tool box from my newer Chevy and had it painted to match. Had to replace the 2nd china hood as it failed in the middle like they all do. This time. I just left off the hinge springs. Heavy, but doesn't buckle. Hold it up with a broom stick! haha. Guess I never took pics of the tool box after painting. I'll add one on the morrow.
I had the painter redo the clear coat on the top of the RED all the way around front to rear as it had started to fade away. The first painter goofed it up somehow, didn't last. When I had the tool box repainted, he also did the top of the cab to boot. Now, the whole truck looks pretty good. Not perfect, but OK.
LBJ is offline   Reply With Quote
Old 01-28-2014, 01:46 AM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: 77 Chevy - Fix for Broken Glove Box Hinge?
Grab a new glove box from an old truck. I have at least 3 extras
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-28-2014, 10:26 AM   #3
LBJ
Wrecking yard huh? Guess I need to make a trip. Thanks Willet.
Old 01-28-2014, 10:46 AM   #4
Jonboy
Slots go on anything!
I think I may have one in the attic if you are unsuccessful. Have to check.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 01-28-2014, 04:20 PM   #5
Your41Plague12
Your41Plague12's Avatar
Make sure you get the correct one too; AC and non-AC trucks are different.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 01-29-2014, 03:05 PM   #6
TheBlueBomber
TheBlueBomber's Avatar
Boom
http://www.gm***************/forum/showthread.php?t=620
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 01-29-2014, 03:05 PM   #7
TheBlueBomber
gm square body is what is blocked out
Austin
Old 01-29-2014, 11:34 PM   #8
LBJ
Jonboy, I have AC. Let me know if you find yours in the attic. Thanks
Old 01-30-2014, 07:02 PM   #9
TheBlueBomber
Did you check out the thread I posted for the hinge repair?
Austin
Old 02-01-2014, 10:45 PM   #10
C10wip
C10wip's Avatar
Well, not sure if he did, but I had a look and did this last night. I bought a 12" piano hinge ( which is not full length but will work) a while ago and hadn't gotten around to it, but my glovebox had fallen completely out so it was time.
Drilled some holes and tacked it on with some 3/16 rivets. The only slight issue was that when I put it back in, the top of the box interfered with the bottom of the dash pad so I have propped that up a little.
Thanks!
1980 C10 Custom Deluxe, 250 L6, 3 in the tree.
C10wip is offline   Reply With Quote
Old 02-02-2014, 04:45 PM   #11
LBJ
Blue Bomber, I looked thru your thread, but didn't see any hinge repair. What page is it on? Thanks.
Old 02-02-2014, 05:09 PM   #12
silverbear
silverbear's Avatar
In a pinch, I used some thick foil tape (like it used on home ac/heater ducts). I put a length of it on both sides of the plastic hinge and it held the two pieces together long enough that I forgot all about wanting to replace it.
Chris
silverbear is offline   Reply With Quote
Old 02-03-2014, 01:32 PM   #13
TheBlueBomber
I posted a link up earlier but it blocked it out for some reason. I'll try posting it up again but adding spaces. I haven't added the fix to my thread yet.
http://gm square body.com/forum/showthread.php?t=620
Austin
