![]() Join Date: Nov 2011
Early style tach cluster
All gauges were working when I pulled the cluster. Includes tach wire harness. One broken / missing mounting tab. $180 includes shipping. (ups ground) Thanks, Jody tavia@plateautel.net (575)-513-2122
Re: Early style tach cluster
Still have this? And will it work in a '79 that didn't originally come with the tach option?
-Jonny B. 1979 Chevrolet K20 Scottsdale: GM350/SM465/NP208 1979 Jeep Cherokee Golden Eagle: AMC360/TH400/D20 1999 Dodge Ram 2500 Larime SLT: Cummins 5.9L 24v/47RE/NP241 |
Hey partner, thanks for the interest. That cluster is gone but I do have another one just like it. With wire harness. I think it's a direct fit if you have mechanical oil pressure gauge in your 79. $180 includes shipping. Thanks again, Jody
That sounds great! I have an electronic oil pressure gauge but would rather have a mechanical. Do you have any pictures? Also, off topic, do you happen to have any gauge/dash bezels for a '79?
That's a 73-75 cluster (the amp gauge gives it away). If you try plugging an amp gauge setup into your volt gauge setup, you'll wind up with crispy wiring.
Just an FYI, the early clusters (73 - 75) used an ammeter so they won't be a direct plug-in swap into a 76 or newer truck.
It'll still fit but you'll have to either (A) modify the truck's wiring to work with the ammeter, or (B) modify the cluster to accept a 76-up voltmeter. Modifying the cluster to accept a voltmeter will likely be the easiest. Also be aware that GM made some significant changes to the cluster plug pin-out in 78. So you'll have to re-arrange some wires on that plug to make everything match up. |
Hey ya'll, Thanks for the excellent info.
PM sent.
