01-28-2014, 05:05 PM | #1 |
Hazard Switch
Hey Guys,
New to the forum, but have been playing with my C10's for a while. My question to the groups is. A 1971 C10, which type of hazard switch should it have. The Red style or the black mushroom style. Thank you for the help in advance Double C |
01-28-2014, 06:50 PM | #2 |
Re: Hazard Switch
My 71 C/30 has a red one
The interior is original (except later model Chevy steering wheel, CB and Pioneer Supertuner). Even though I've got a C/30 I figure a C/10 would be the same. Don't know if there was a midyear change but my truck was built in April 1971 if it matters.
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72 1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code" 1970 Mercury Cougar "Eliminator" 351C-4V C6 1972 Ford Ranchero GT 351C-2V C6 1974 Honda XL-350 Member of the "6 C's and a D" 1-Ton Fun Club! |
01-28-2014, 07:01 PM | #3 |
Re: Hazard Switch
71 Dually,
Thanks for the photo and the information. I found a 4 speed tilt column that I'm going to install, and I found a company that sells the Red switch style turn-signal assy., just trying to make it look correct. |
01-28-2014, 09:03 PM | #4 |
Re: Hazard Switch
Where did you find it? I need to replace my broken one.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
01-29-2014, 11:44 AM | #5 |
Re: Hazard Switch
NC_John,
A company in CA called M&H electric has replacement harnesses and components |
01-29-2014, 01:10 PM | #6 | |
Re: Hazard Switch
http://67-72chevytrucks.com/vboard/s....php?p=4250625 Last edited by FirstOwner69; 01-29-2014 at 01:15 PM. |
01-29-2014, 01:59 PM | #7 |
Re: Hazard Switch
The truck tilts do not use the red flasher style. They use the black style or there is a chrome flasher knob that looks great!
01-29-2014, 03:57 PM | #8 |
Re: Hazard Switch
Here's a picture of the chrome knob 70shortfleet mentioned installed.
01-29-2014, 10:19 PM | #9 |
Re: Hazard Switch
Thank you sir- I helped install an M&H harness last weekend.
01-30-2014, 12:26 AM | #10 |
Re: Hazard Switch
Sorry to too high jack the thread but this might help out some other poeple. My red hazard nob is broken and i would like to replace it. Is there a way to replace just the knob, or do you have to replace the whole switch. The turn signal swtich with red knob was 42.00 at M&H.
01-30-2014, 06:25 AM | #11 | |
Re: Hazard Switch
I went through the M&H site but didn't see the hazard switch. What's the PN? I haven't been able to find a repop of the original red button by itself, just the round black ones....
12-03-2020, 12:53 AM | #12 |
Re: Hazard Switch
Will that chroma known work with a non tilt column instead of the red one?
12-03-2020, 10:49 AM | #13 |
Re: Hazard Switch
12-03-2020, 11:25 AM | #14 |
Re: Hazard Switch
That is the tilt column turn signal harness? Will that still work with the non-tilt? Thank you!
12-03-2020, 12:37 PM | #15 | |
Re: Hazard Switch
They are even located in Oregon |
12-03-2020, 01:17 PM | #16 |
Re: Hazard Switch
Thank you for leading me to it!!
12-03-2020, 09:10 PM | #17 |
Old member
Re: Hazard Switch
Sorry guy's but yes the tilts use the red flasher knob. I have them in both my trucks. I have the factory tilt in my 71 C-10 that I took out of a Blazer 30+ years ago and it had the red knob.
https://67-72chevytrucks.com/vboard/...d.php?t=733325
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-04-2020, 10:11 AM | #18 |
Re: Hazard Switch
Andy, just because your 2 tilts have the red hazard knobs doesn't mean that they came that way from the factory! Let's do a poll of everyone that's had a factory tilt column and you will see that from the factory they used the black hazard knobs. I've had about a 100 tilt columns and at least 95 of them had black knobs on them.
12-04-2020, 10:47 AM | #19 | |
Old member
Re: Hazard Switch
What ever man. I just know they came with them. I grew up riding in them and the black ones never came in these. Unless they were motor homes are vans. The c-10 had the red ones. My dad drove these trucks all my life and never saw a 72 -71 with a black e switch...never. Pole doesn't prove anything except what people believe, just like the brake pedal having 2 holes in it. Never happened from the factory.
06-15-2023, 04:17 PM | #20 |
Re: Hazard Switch
72 GMC red hazard switch from the factory. Broken also.
72 GMC Sierra 2500 |
