![]() Join Date: Jan 2013
Oil Leak
I have 71 w/ 307 3OTT with a oile leak. Given the cold I have not had a chance to thoroughly inspect, but wanted to see if anyone had an idea.
I am getting a significant motor oil leak out of the inspection cover of trans. Left a good size puddle last night. The back of oil pan is wet, rear main? or pan gasket? If it is rear main how hard to change? |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Oil Leak
Sudden onset bad oil leaks are very often the oil pressure gauge fitting on the back top of the block. They run downwards and can mimic a rear main leak.
![]() Join Date: Aug 2007
Re: Oil Leak
give it a good engine degreasing then buy the oil additive that dyes the oil so you can see the leak with a black light, both very cheap and you will have an exact location of your leak and the dye does not hurt the oil or engine. NAPA or O`rileys and auto zone carry them.
Scotts72C10 |
Re: Oil Leak
Does it need to be replaced or just tightened?
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
Re: Oil Leak
If its an electric sending unit type like for the dash with oil pressure light rather than gauge, you replace it.
If the truck has oil pressure gauge, its a little copper line that goes from the engine to the back of the gauge. You'd want to look closely at it to see if its cracked or what. We haven't heard back from the OP yet to see what he found.
![]() Join Date: Dec 2013
Re: Oil Leak
The easiest way to find any type oil /trans leak is to wash the engine down with mineral spirits and once dry use baby powder and sprinkle engine /trans to locate leaks ,this procedure is used daily by aircraft mechanics to quickly find any leak in an engine ... try it ,I really works and is easy to clean off with clear water when done !
#7 | ||
"I ain't nobody, dork."
Re: Oil Leak
Lots of variable to oil leaks. Could be the pressure sending unit/line, rear intake manifold valley seal, valve cover gaskets, or the dreaded rear main seal.
However... the ones that come from the top (sending unit, intake, valve covers) can look like a rear main seal leak. Check up top first. Gary
Re: Oil Leak
I replaced the oil sending unit, it was leaking. I am still getting a drip from the trans insp cover, but it may be residual oil from the leak. It was 10 degrees when I replaced so to cold for me to do a thorough cleaning. Today is warmer so I will degrease and see if I find anything else. Once again, thanks for all the good info!
Re: Oil Leak
To answer your question about how hard it is to replace the rear main: you may have to lift the motor to get the pan off. After that you can usually roll the upper half of the seal out after removing the rear main cap. They used to sell a corkscrew tool to get ahold of the seal.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
#10 | |
Re: Oil Leak
I to have a oil sender leak on the truck. I thought it was the valve cover. I have seen a sender go bad and pump oil out the wiring connector before. Had that happen on a grand am right after rebuilding the engine. Made for a fun WTF on the maiden voyage. |
