01-26-2014, 10:46 PM | #1 |
Small block on 6 cylinder mounts?
I have a 68 c10 that I have a 350/700R combo, Is there enough fire wall clearance to run 6 cylinder mounts? I have both forward V8 mounts and the rear 6 cylinder mounts. Would prefer to run the 6 mounts to clear the headers I bought. Is there enough room to run a HEI Distributer with the 6 mounts. We used the same mounts on my sons 66 c10 (6 cylinder) and worked great with a small block, but we had to modify the firewall when he put in a big block. I would appreciate any input you guys have. Thanks john
01-26-2014, 11:11 PM | #2 | |
The Older Generation
Re: Small block on 6 cylinder mounts?
It will be really close. You could always use the divorced coil HEI for more clearance. LockDoc
01-26-2014, 11:36 PM | #3 |
Works fine in my truck. Just about 3/4" clearance between the HEI and the firewall.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
01-27-2014, 12:05 AM | #4 |
Thanks guys, appreciate the input
01-27-2014, 12:22 AM | #5 |
If you don't mind your firewall looking like this, it can be done. My truck originally had a 6cylinder and the PO decided to put a small block in with out changing to the correct engine stands. I have a few more pics on my build thread if your interested. But I for one would not do it.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
01-27-2014, 07:55 AM | #6 | |
01-27-2014, 08:47 AM | #7 |
If you move the 6 cyl mounts to the forward holes in the frame, you will have plenty of room.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
01-27-2014, 11:38 AM | #8 | |
He mentioned in his first post that he needed to use the rear 6 cyl mounting location for header clearance issues. That's the way I understood it anyway... LockDoc
01-27-2014, 12:36 PM | #9 |
Well, I guess I could have read a little more closely. I'm not sure if he's talking the position of the mounts or whether they are for 6 or 8 cyl.
01-27-2014, 12:39 PM | #10 | |
I wondered about that too. LockDoc
01-27-2014, 03:24 PM | #11 |
Watch out for your cornhole !
I've done it more than a few times. Never any issue or need to dent the firewall. You can still side your hand between the back of the distributor cap and the firewall. You can still pull your distributor without issue.
01-27-2014, 04:18 PM | #12 |
I just put my engine in last night and I set in in the 6cyl position and had plenty of room. I have a tbi small cap but it looks like the bigger hei cap will fit.
I did it just to try and get my driveshaft as short as possible. I'm just wondering if it will make a difference in how the truck drives and handles? |
01-27-2014, 11:51 PM | #13 |
I am wanting to put a v8 on 6 cylinder mounts (rear mounting holes) with an big cap HEI
01-28-2014, 12:14 AM | #14 |
This is a small block in the 6 cylinder mounting location with standard HEI cap. About 3/4" clearance on the firewall.
01-29-2014, 11:21 PM | #15 |
Thanks Lattimer, that's the money shot right there. exactly what I was looking, John
01-29-2014, 11:49 PM | #16 |
Other than clearance for exhaust, why do some people use the 6 cyl location? What are the advantages or disadvantages?
01-30-2014, 12:58 AM | #17 | |
1. Don't have to move the trans crossmember 2. Don't have to modify the driveshaft 3. Don't have to modify the clutch linkage 4. More room in front of engine for accessories, electric fans, etc. The only performance advantage is that it does shift weight toward the rear, so it can help handling a little bit. When I swapped in the TREMEC, I debated on moving my engine forward. I was getting a custom driveshaft and the kit came with a new crossmember that I had to locate. I have enough room in front for the fans and whatnot. A little more clearance at the back of the engine would make changing plug wires easier. Last straw was modifying the clutch linkage. Whoever installed the V-8 modified the L-6 Z-bar, and I would have had to do some fab to make it work in the forward position. Plus I would have had to mod my exhaust. Didn't seem worth it, so I put the engine right back where it was (I swapped the 327 for a crate 355 at the same time I did the TREMEC).
01-30-2014, 09:41 AM | #18 |
Thanks lattimer. That's good info to know. That shorn is a purdy engine ya got there!
01-30-2014, 10:17 AM | #19 |
Thanks. Unfortunately, that one came right back out. Started knocking after about 50 miles. Its still on the engine stand, I haven't gotten the courage to open it up. I got pissed off and bought a Vortec 355 crate motor and dropped it in.
01-30-2014, 10:21 AM | #20 | |
Rottenwood Garage Member
Yep...move them forward. I think you will need V8 stands. Why crowd the firewall and leave an ugly gap between the fan and radiator. Do it right the first time. I have passed on buying trucks that had the V8 conversion in the I6 holes.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 01-30-2014 at 10:42 AM. |
01-30-2014, 10:40 AM | #21 |
The last two stepsides I bought had small blocks in the 6 cyl stands,Luckily I had parts trucks with the v8 stands as the 6cyl and v8 stands are different they wont move to the front holes ,at least the ones I had would not work and it gave me alot more room behind the motor
39 GMC pickup,70 GMC K1500 short bed 4x4 ,72 K10 short bed step side 4x4 ,71 short bed fleet side , 72 K20 long bed ,74 K10 long bed , 69 C30 dump bed dually, 79 K30 standard cab dually , 02 Dodge 4x4 dually |
Tags |
6 cylinder, c10, small block, v8 mounts |
