Old 01-30-2014, 11:45 AM   #1
StoningtonQB
StoningtonQB's Avatar
Powder coating the air cleaner
So I picked up an original air cleaner recently and am getting ready to do a media blast and a powder coat in semi-gloss. The dilemma I'm having is what to do about the Thermac valve. I don't want to drill it out to remove it for coating, and at the same time have no intention whatsoever of ever making it functional. It may work, but I don't know for sure (and I don't care to find out). However I want this to LOOK original so I have been toying with the notion of just coating right over it. Would there be any problem with having this done? I still want to hook the vacuum lines back up afterwards to give it the appearance of a functioning valve. I'm wondering if the powder coating guy will give me any balls about it.
StoningtonQB is offline   Reply With Quote
Old 01-30-2014, 12:10 PM   #2
DT1
DT1's Avatar
Re: Powder coating the air cleaner
I had mine powder coated (Thermac valve and all), no problem.
DT1 is offline   Reply With Quote
Old 01-30-2014, 04:10 PM   #3
Rich916
Rich916's Avatar
Did mine,T/valve and all. I went with a high gloss...give a little more "bling" factor.
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 12-13-2014, 08:21 PM   #4
slikside
slikside's Avatar
Almost a year old thread, but it's right at my topic....
Anyone see an issue with also powder coating the heat riser tube??
I imagine that thing gets pretty warm, cuz that's what it's there for, but will that cause any issues with the powder coat, like cracking, blistering, etc??
Don't want to spend money to do it if the heat will damage it. I would just paint it in that case.
Thanks.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 12-13-2014, 09:54 PM   #5
Steve Hafner
Steve Hafner's Avatar
Thanks.
I don't know how powder coating would work, BUT . . .
I painted my heat riser tube and manifold "cover" with high temperature paint.
It's lasted for three years so far - but I don't drive it very often.
A small part of it has faded a little, but hardly noticeable.
They WERE black from the factory, as seen on this 80 mile engine:
( a lot glossier then most people think too !!! )
Steve Hafner is offline   Reply With Quote
Old 12-13-2014, 10:23 PM   #6
slikside
slikside's Avatar
High temp paint...duh! Didn't even think of that.
Definitely an option if pc-ing is an issue.
Thanks!
Old 12-14-2014, 10:12 AM   #7
88fordf150
88fordf150's Avatar
You would need to use high temp powder coating on the riser tube. Regular power will not hold up very well near the exhaust.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 12-14-2014, 10:50 AM   #8
slikside
slikside's Avatar
OK, thanks for the heads up. Didn't realize they had "specialized" powder coats. I will keep that in mind if I go that route.
Old 12-14-2014, 12:21 PM   #9
88fordf150
88fordf150's Avatar
I used some from Columbia Coatings on a set of exhaust manifolds, held up real nice. They only had silver and black when I did them but it wasn't as shiny or glossy as regular powder.
Brad handshoe
Old 12-14-2014, 03:37 PM   #10
Lou Boffa
Lou Boffa's Avatar
subscribbed
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 12-14-2014, 08:39 PM   #11
71 super
71 super's Avatar
You can powder the tube, did the one on my bb nearly 10 years ago and it still looks new
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 12-14-2014, 11:05 PM   #12
slikside
slikside's Avatar
Right on. Do you recall if you did any kind of special high-temp pc, or did you just go the standard route??
Old 12-14-2014, 11:12 PM   #13
slikside
slikside's Avatar
Thanks. I'll have to ask the powder coaters what they use. That had to have been a high temp type of pc I would think.
I have to believe that if you can pc exhaust manifolds, and they held up well, then a riser tube should be a non-issue with just about any kind of pc. I mean, the thing doesn't even touch the exhaust manifold, only the thin metal shroud around it.
Old 12-15-2014, 09:37 AM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It will be fine to do the tube with regular powder.
The exhaust manifolds need ceramic coat. No big deal, most powder shops spray ceramic too.
High temperature powdercoat is not good stuff. Most coaters won't even use it anymore.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-15-2014, 06:03 PM   #15
slikside
slikside's Avatar
Thanks Kevin, I appreciate you chiming in here. I know you do this sort of work yourself, so yours is a valuable opinion to have. I think I'll go ahead and have this done.
Thank you for all the comments guys. Much appreciated.
Steve
Old 12-15-2014, 07:27 PM   #16
Tx Firefighter
You're welcome Steve. I know it's not a heat tube, but I powdercoated a metric butt load of motorcycle exhaust heat shields. They bolt directly to the hot pipes.
I was kind of showing off there with that one. Most folks say you can't two tone powdercoat. I figured I'd do a three tone to prove them wrong. Remember, if it's worth doing, it's worth overdoing.
Since I am mostly a motorcycle guy, my ceramic coating was mainly silver and semi gloss black.
The black seen here on my one of my own personal Yamahas.
Silver here on a Moto Guzzi exhaust system.
Most custom coating shops shoot ceramic alongside their powder work. They kind of go hand in hand. Ceramic is killer stuff. Just treat it like something you paid good money for and it will last. What I mean by that is don't beat it up, install it with some form of care.
As a durability test I did the entire system on my rider motorcycle and have purposefully treated it bad to see how it lasts. So far, I'm at the three year mark and haven't even washed the motorcycle even once. I treat it like a whore on 5 dollar night. Lots of bug guts, mud, and road debris have bounced off of it. So far, all is well.
This picture was taken three years ago when I first built the bike. It looks like a sack of smashed up buttholes now. I'm making a statement against all of the chrome and polish guys who'd rather clean them than ride them.
