Old 01-31-2014, 01:25 PM   #1
WhippinSaw
WhippinSaw's Avatar
manual steering box for a '63
I want to replace the steering box and I am looking for a new or rebuilt. I found this one at classicparts http://www.classicparts.com/1960-66-.../#.UuvV2vldUhM and they said it was for a three speed and would not be an exact fit for my powerglide. I am confused because I thought all 2wd manual steering boxes for 60-66 were the same. Does anyone else know were I can buy a new or rebuilt unit that would bolt right up?
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 01-31-2014, 02:32 PM   #2
VonDog
VonDog's Avatar
Re: manual steering box for a '63
They're not the same or should I say there are several different ones. I had mine rebuilt cause I couldn't find the right one for my K-20. Search for a shop that rebuilds them. Mine came out Perfect and it was right at $200. Good luck and hope this helps.
VonDog is offline   Reply With Quote
Old 01-31-2014, 02:36 PM   #3
VonDog
VonDog's Avatar
Oh yeah, the place I used was Benchworks Steering out of Scottsdale or Tempe Arizona.
Old 01-31-2014, 09:17 PM   #4
duallyjams
duallyjams's Avatar
These guys have the fastest turn around
http://www.redheadsteeringgears.com/
post 96 http://67-72chevytrucks.com/vboard/s...=502124&page=4
I have used them on friends rides also.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-31-2014, 09:36 PM   #5
WhippinSaw
WhippinSaw's Avatar
Thanks guys, sounds like a plan. Last part to repair.
Do I have to match up my rag joint or can I buy one of those
From an online vendor? Never messed with a steering box.
Also should I just replace the pitman arm? Looks like Dually Jams
just reused his old ones.
Old 07-10-2014, 01:58 PM   #6
1963c-10
1963c-10's Avatar
Did you ever get your steering box sorted out? I've got a small leak that's developed in the pitman shaft seal?
I sent Redhead a message to see what they charge for a rebuild.
1964 Short bed trailer
Old 07-10-2014, 03:23 PM   #7
ProudSoul
ProudSoul's Avatar
Check out American Classic Truck Parts. I bought a rebuilt box from there for $175 + $100 core charge. Got my box in 3 days I think!
ProudSoul is offline   Reply With Quote
Old 07-10-2014, 04:32 PM   #8
1963c-10
1963c-10's Avatar
They've gone up to $250 now and no mention of a core. Guess a phone calls in order. Thanks for the heads up!!
Old 07-10-2014, 11:25 PM   #9
WhippinSaw
WhippinSaw's Avatar
I took the box to a machine shop downtown Chicago that was recommended by a mechanic at work, rebuilt it for 225. The mechanic at the machine shop was very knowledgeable and did a good job. Came out nice, he resealed it and painted it and no more play in the steering. Maybe you can find a good local shops round you.
Old 07-11-2014, 08:16 AM   #10
1963c-10
1963c-10's Avatar
Thanks for the reply. Everything feels tight, its just the pitman arm shaft seal that's leaking, so I may just do it here at the house.
Old 07-11-2014, 10:11 AM   #11
65 C20
Check out the section on Suspension.
Tx Firefighter did 2 articles.
Back to the basic rebuilding the rag joint and steering box.
Lots of pictures and simple instructions
65 C20 is offline   Reply With Quote
Old 07-11-2014, 10:16 AM   #12
1963c-10
1963c-10's Avatar
Yeah, I remember the rag joint thread. Actually picked up the rebuild kit for that last night. I'm going to do the steering box seals and bushings myself. Haven't done a steering box, but 1st time for everything.
