mustang ii steering link pics please!
I need some steering column linkage pics with mustang rack in AD trucks.
Thanks. |
![]() Join Date: Mar 2011
Re: mustang ii steering link pics please!
These are not the best pics, but all I have. First pic shows being set up for length of shaft. I use wooden dowels to put inside the universal, once everything looks OK, then I cut the metal one. Second pic is metal shaft installed. I must tell you that I moved my steering column over about 2-1/2", and down a little from the stock location, so it would clear my headers better. You can see old spot in first pic. Mine runs straight from the joint on the column to the rack. Hope this helps....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
![]() Join Date: Jul 2012
Here is one with a vibration reducer joint at the column, DD shaft, single joint, and support to get around the exhaust manifold.
ididit 32'' column, modified column drop, TCI IFS
