Old 02-01-2014, 10:04 PM   #26
quadzero
quadzero's Avatar
Re: Moby: My Chevy 4x4 ls swap
Originally Posted by Greenlee View Post
I really liked the old truck. Looks like this one will be just as nice!
Originally Posted by bohmankid View Post
Next on agenda is cleaning and painting this nasty radiator support. Too bad I picked a bad time to start working on my cars outside.. it's cold!
You are already off to a great start. Loved your last WIP. The frame is excellent, perfect home for the LS. I was curious, how cold does it get there cause until it is spring time I'm not doing much outside except for shoveling snow. And thanks to Hankster for the link.
quadzero is offline   Reply With Quote
Old 04-02-2014, 09:21 PM   #27
Big Rat
Big Rat's Avatar
Sooooooo, anything new?
Evan
'69 C20 - Grandpa's 'ol truck
'70 Nova - Birthday present from the wife. She's a KEEPER!
'79 C10 - High school hot rod, BUILD THREAD
Big Rat is offline   Reply With Quote
Old 05-17-2014, 01:09 AM   #28
bohmankid
bohmankid's Avatar
Originally Posted by hardcore4life View Post
Is that LS Prius your brain child or someone else's?
Someone else's. I found it on one of my web surfs.
Looks like you are making some good progress. That white under the hood makes it look nice and clean
Thank you! The white really sets the motor off.
Originally Posted by y5mgisi View Post
Subscribed! For the computer mount, mount it on the inner fender. Use the $12 ebay mounts. Search, ls1 computer bracjet".
Thanks. I'll search for one and see if I like it.
Originally Posted by Hankster View Post
Looks good, I've seen worse looking rims on the road before! Keep up the good work.
Well I decided to scrap the rims anyway. I'll just get new ones.
Thanks! It gets pretty cold here. But It also gets pretty hot. As you can see from my post dates I didn't do anything all winter cuz it was anywhere from 5-30 degrees F these past Winter months. It was over 80 today though.
I've been finishing up this truck slowly. Buttoning up stuff and putting all the little things on. Here are a few engine bay shots.
Also, I want to make 2 containers or trays for the fuse block that I built and for the computer sitting on the inner fender. Do you guys suggest anything I could use or build to put these things in/on? Thanks Y5, I'll check out your recommendation as well.
bohmankid is offline   Reply With Quote
Old 05-17-2014, 01:14 AM   #29
bohmankid
bohmankid's Avatar
One more picture
Old 05-17-2014, 05:23 AM   #30
Greenlee
Greenlee's Avatar
Looks good! Looks like you are almost done.
Greenlee is offline   Reply With Quote
Old 06-25-2014, 09:42 PM   #31
Hankster
Hankster's Avatar
Anymore on Moby?
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 07-23-2014, 05:11 PM   #32
bohmankid
bohmankid's Avatar
Unfortunately I'm far from done, my friend.
I decided to take the truck in a different direction. I'm not completely done working out the bugs of the motor swap yet, but I'm starting something new on this truck while I finish all the little things.
Any guesses what I'm doing?
Old 07-23-2014, 05:12 PM   #33
bohmankid
bohmankid's Avatar
Let me just say I sure do wish I had a lift.. or a big enough garage..
Old 07-23-2014, 06:06 PM   #34
franky69c10
chevy runs deep
franky69c10's Avatar
What are you using for the wire harness to start the engine, after market or did you do it your self
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 07-23-2014, 08:56 PM   #35
bohmankid
bohmankid's Avatar
Stock, re-worked harness. I spliced it into the truck and made the fuse block myself. I sent the computer to Brendan at lt1swap.com to turn off emission stuff, adjust fan settings and turn off the electronic transmission to turn it into a standalone harness for the engine. I kept the transmission connectors on the harness though because I plan on putting in an overdrive in the future. I've been thinking about buying an aftermarket harness. But I haven't justified the prices they're going for yet.
Old 08-12-2014, 10:40 AM   #36
bohmankid
bohmankid's Avatar
Installed a 6 inch Super lift on the front. Also coated the front axle in por15.
Check out the difference in arch between the stock spring and the 6" Super lift spring. I'm in need of oversized mud terrains now..
Old 08-12-2014, 10:01 PM   #37
Greenlee
Greenlee's Avatar
What's your plans? Looked like it was going to be a dually in one of your pictures!
Old 08-16-2014, 03:10 PM   #38
Hankster
Hankster's Avatar
Looks good with that lift! You should do it up Cali style with some 15x12 and some 33s with that lift..
Current Build
Old 08-25-2014, 03:20 PM   #39
NorCalAnthony
Any updates on Moby? Your truck looks great so far
NorCalAnthony is offline   Reply With Quote
Old 08-27-2014, 01:54 PM   #40
bohmankid
bohmankid's Avatar
I got the bed back on and put all the new shocks on except for one in the rear because the mount to the frame broke! Does anyone know where I can get a new shock mount? Autozone/O'Reilly both failed me. Figures.
Anyway, now that this lift is on, I need help picking out wheels and tires! Here's a few examples chrome or black??
Old 08-28-2014, 12:37 AM   #41
y5mgisi
Second Chance Program
y5mgisi's Avatar
If you must do rock stars, i vote black.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 08-28-2014, 12:57 AM   #42
bohmankid
bohmankid's Avatar
They were the easiest images to photoshop haha. I probably won't go with this specific wheel, just having some fun!
Looks good though
Old 08-31-2014, 01:43 AM   #43
NorCalAnthony
If you're keeping the grill, mirrors, bumpers, etc chrome, then I'd keep the wheels either chrome or maybe the ones with the black centers and machined faces. The black wheels can look cool but need more black accents on the truck to look right IMO.
Old 09-02-2014, 01:10 AM   #44
treborjm
treborjm's Avatar
Sorry for the loss of Bear! It does seem that you are off to great things with Moby.
What's the story with the red truck in your avatar? Is there a build thread for that truck too? I've see the youtube videos of it running.
Thanks for posting great write ups!
treb
treborjm is offline   Reply With Quote
Old 09-02-2014, 11:24 AM   #45
bohmankid
bohmankid's Avatar
Thanks for your opinion, most people I've talked to about wheel color have voted chrome as well! I'll keep the thought of adding black accents to the truck though. Still haven't pulled the trigger on a wheel/tire package.
treb
Thank you for reading my threads! Im glad a few people enjoy them. There is no build thread for the truck in my avi. I owned that truck for a total of 6 months before i knew about this website, but I had a ton of fun with it. Since you asked, I'll post some pictures of it! Dont forget, you asked for it!
I welded up a cool 3 inch exhaust with 4.5" chrome tips
I installed a nice highliner headliner
I installed 2nd row seats out of a 2011 tahoe
Then one miserable day, someone accidentally backed their truck into mine
So I replaced the panels and did some body work
Still had fun though
Painted the bad panels. It's a burnt orange color by the way, not red. Pics don't do the color justice.
Still used this pretty truck in the mud and dirt. It ain't only good on pavement.
The orange truck had a built 350 with a large cam and a 4 speed with the granny gear. It actually spanked local Hondas in races and it made me feel good! Sounded like a big block. Would NOT pass emission tests, so that sucked. Had a 6 inch skyjacker lift with 35 inch toyos and 20 inch wheels. A very fun truck but I ended up trading it for a camaro and mustang package. I go through cars quite a bit.. I've had so many others.
Old 09-02-2014, 11:26 AM   #46
bohmankid
bohmankid's Avatar
By the way, I got that rear shock mount from Napa.
Old 09-02-2014, 11:32 AM   #47
bohmankid
bohmankid's Avatar
Here are a few vids of my avi gmc i took way back when i was the ignorant age of 18! Enjoy
Old 09-02-2014, 11:44 AM   #48
bohmankid
bohmankid's Avatar
Old 09-03-2014, 08:51 AM   #49
bohmankid
bohmankid's Avatar
I drove Moby around last night and that 5.3 sure is peppy! Just like I remember it. Still have to work out a few bugs and wire a few more things up. And the truck wanders pretty bad on the road. Also needs an alignment because my steering wheel is upside down, my right turns are wide and it will turn left on a dime. I put the wheels off Bear on Moby just for fun to see what it would look like.
Old 09-06-2014, 12:20 PM   #50
tip
Nice truck!!! Love the 5.3 swap.
One question. Your black trim along the lower sides of the truck, is that stock? I'm trying to find an alternative to that stick on chrome LMC stuff, and I haven't seen straight black before.
tip is offline   Reply With Quote
