02-02-2014, 05:43 PM | #26 |
Re: Why do I want an LS motor?
if you have the np205 then its a little harder and im not as keen on them but i think you just get the adapter and shorten lengthen the ds. if you could find a ome od truck though you can get the 208 and ds from it direct bolt up.
02-02-2014, 08:32 PM | #27 |
I kept my th400 for the exact same reason you stated. I plan on putting an OD trans in when funds allow and I want to drive the thing NOW. lol.
Also, I'm planning on doing a 4l80e instead of the 4l60e. My PCM will need to be tuned for the 4l80e and the cross member will need to be moved back. Cool thing about the 4l80e is it will bolt directly to the old transfer case and you don't need any special adapter. And about the VSS, I bought mine from dakotadigital and it lets me use my stock speedo gage with cable. |
02-03-2014, 09:47 AM | #28 |
to not swap while you do the engine id double the work is what im getting at. you can have the engine bolted to the trans and stick it all in at once alot easier. the 4l60e is direct bolt for the np208 the 4 to 6 adapter is included in new trucks from the factory. so when you getting the 4wd tranny just grab that with it. the np205 idk for sure but the adapter may work on it too.
02-03-2014, 10:32 AM | #29 |
I've got the np203. I haven't made the decision yet about the 208. When I do put the 4l60e in I'll most likely go with a 208. I want to do the swap without having do modify the drive shafts first and then finish up later with the transmission swap.
Heck if there is a deal going on I might end up going with a SM465.
Austin 1996 Chevrolet K1500 Silverado 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
02-03-2014, 10:39 AM | #30 |
Ephesians 2:8
I'll tell you what I did on my nephew's truck.
5.3/4L60E/ NP241 from a 91 Sub. ( VSS built in ) Used a 91 Sub/Blazer dash cluster that has the elec speedo already. Looks stock ( not 73-80 stock but close ) I was able to find a rear drive shaft that would work, but he had to shorten the front. The NP208/241 Linkage is the same for what thats worth. If you want to run OD some day, I would do it all at once, one and done. But that is just me, there is something to be said for doing just the enigne, your going to see improved mpg, and more Smiles Per Gallon over the engine you have now. Nephew's truck sits on 35's 4" of lift and he see's 16-17 just running around. It made it a nice truck. And its actually a pretty quick truck with the 4.10's in it.
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
02-03-2014, 11:12 AM | #31 | |
02-04-2014, 03:03 AM | #32 |
Interesting how much gas mileage would something like the 6.0 put out and 5.7.I wonder how much those cost and would people recommend these ls for towing.
1982 chevy silverado It's all about original guys original let me say again original. |
02-04-2014, 10:53 AM | #33 |
Ephesians 2:8
I did an LS swap on my 94 K1500. I use it as my work truck. Tows great, improved MPG. And will walk any newer truck from a light
02-04-2014, 11:25 AM | #34 |
Your right. I have a daily so it shouldn't be a big problem to let this sit. I might end up getting this done sooner than expected.
02-04-2014, 06:21 PM | #35 |
it all depends on what your towing and what trans. all are capable of the mid teens. i had a 01 4wd 4.8 truck i would pull 6-7k behind it all the time it would get about 15 mpg when hooked to the trailer. when unloaded i saw up around 23-24 mpg once on the highway. could avg around 20 mpg. in a half ton the 4.8 or 5.3 would be what i would want. now with a hd truck id def want the 6.0 or 6.2. the 5.7 was mostly a car motor and not as common i wouldnt recomend them for truck use unless i just got it for the right price. not enough bottom end really. basically would be like a new truck in the old sheet metal. if you have a 4wd truck just find a new junked 4wd and gut it same for a 2wd. all are better than the older sbc imo.
02-08-2014, 06:58 PM | #36 |
Okay. You guys got me. The new "Sith Lord Apprentice" has joined the dark side lol.
I'm 1000% going with a 5.3. But with a twist, and it starts with a "T", and ends with a "turbo" Can anybody guess what that is?
02-11-2014, 11:51 AM | #37 |
Ephesians 2:8
Twin Turbo... cause if it was a single, it starts with a "T", and ends with a "urbo" I would say single....
02-11-2014, 05:52 PM | #38 |
awesome but i will say this it is much easier to sc one of the engines than turbo.
02-11-2014, 08:03 PM | #39 | |
Yes it is. Especially since I've only just started learning about turbos but I'm up to the challenge. I think it'll be an interesting first build to say the least.. i happen to be a very creative person so the planning on paper portion will be stupid easy for me.. the hands on part should be entertaining for ya'll haha.
02-11-2014, 08:06 PM | #40 |
Oh and by the way... this should be here early next week.
02-11-2014, 09:07 PM | #41 |
It's too bad that the newer engines look so cluttered in an older engine bay if they are left stock , there is a lot of stuff to deal with to make it appear cleaner - $$.
02-11-2014, 09:54 PM | #42 | |
"NO BAGS JUST PLAIN LOW" |
02-12-2014, 11:31 AM | #43 | |
I'm still contemplating turbo or supercharger for mine. At my elevation in these Rocky Mountains, there's nothin else like boost. Dirty Dingo motor mounts and 5th gen Camaro long tubes (eBay headers) |
02-12-2014, 11:46 AM | #44 |
Yeah... I gave up on the budget part.
02-12-2014, 03:48 PM | #45 |
Like everyone else has said......go with the o.d. now. You will not be happy with the th350 or a sm465.
My 5.3 & 4l60e gets 18mpg in my 78 crew cab dually with 4.10 gears.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
02-12-2014, 04:56 PM | #46 |
The "dark side" grows stronger
I have been looking for a new engine for a year now, and finaly found what I wanted. Dipped in to the piggy bank 5 min ago and now I own a 2004 6.0 with 31000 mile on it. The guy I got it from had all the parts for the swap, he had plans to drop it in a 62 Cadillac. But decided to go original instead. Now I only need to get some engine mounts and get started
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
02-12-2014, 05:09 PM | #47 | |
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
02-12-2014, 05:40 PM | #48 |
I payed 4800 for everything. I like that all the parts come from the same truck,should make things easyer than having a mix of things from different donors.
It came with a new harness and clean ecm. He even gave me the transaxel,exhaust and other bits and pieces from the parts truck.I haveŽnt sorted trough everything yet. Just made sure that I had all the essential stuff for the swap
02-12-2014, 05:52 PM | #49 | |
I'm afraid of driving in the snow not because of the snow, but because of the people.
02-12-2014, 06:31 PM | #50 | |
