Old 02-02-2014, 09:45 PM   #1
heathbirkendahl
Hose from windshield washer
Can someone tell me where it hooks up? I assume a pump that would spray it. Maybe Im missing something.
Is it under the hood or in the cowl?
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 02-02-2014, 09:49 PM   #2
gonnuts
gonnuts's Avatar
Re: Hose from windshield washer
Under the dash
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4
gonnuts is offline   Reply With Quote
Old 02-02-2014, 09:51 PM   #3
heathbirkendahl
Originally Posted by gonnuts View Post
Under the dash
Ok. So it does go through the firewall. Found it dragging under my truck. LOL
Old 02-02-2014, 10:00 PM   #4
gonnuts
gonnuts's Avatar
Yep 1 in 2 out I believe
Old 02-02-2014, 10:07 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Outlets are on the windshield wiper motor.
LockDoc
Leon
Old 02-02-2014, 11:15 PM   #6
heathbirkendahl
LockDoc
Thank you guys.
Old 02-02-2014, 11:34 PM   #7
truckster
truckster's Avatar
BUT...
If you want a great and easy upgrade, a washer bottle with integrated pump from an S-10 does a lot better job than the factory unit and it's easy to wire to the existing switch.
truckster is offline   Reply With Quote
Old 02-03-2014, 11:01 AM   #8
bigmac73
bigmac73's Avatar
Originally Posted by truckster View Post
BUT...
any thread or link available to cover that ?
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-03-2014, 11:20 AM   #9
LockDoc
LockDoc's Avatar
Try this one...
http://67-72chevytrucks.com/vboard/s...d.php?t=555852
It also shows how to wire it to your wiper switch.
LockDoc
Leon
