Closed Thread
Old 02-03-2014, 02:19 PM   #51
earl84
Re: What did you do to your truck today part II.
The past several days I got my big block cleaned up and painted and picked up an entire crossmember from a '79 C20 to swap in and got it cleaned up. Got a lot of new parts coming for both prior to installing. Will do the final cleanup and paint on the crossmember after getting the parts installed.
earl84 is offline
Old 02-03-2014, 04:28 PM   #52
wayno
Busy couple of days - got the front fenders all mounted with prothane bushings for the cab and up front. Cleaned up the gauges getting that ready to go back in - and cut down the rubber mounts that hold in the radiator so my new champion radiator will fit inside it without bending the bracket. Ready to put the new shroud and fan on tonight... busy boy.
64 Step Side - The Mistress
wayno is offline
Old 02-03-2014, 06:34 PM   #53
mr andrerson
looking good Wayno!! who's A arms are you using? what size rim/tire combo are you using?
mr andrerson is offline
Old 02-03-2014, 06:38 PM   #54
mr andrerson
didnt see your build til after i posted... duh. That PB stuff is sure purty..
Old 02-03-2014, 09:47 PM   #55
wayno
Yeah man - the PB stuff definitely makes it look real good. Got the fan mounted to the shroud... shroud attached to radiator and cut the upper radiator hose. I also fabricated up a bracket and lengthened things to get the manual clutch back into operation. Need to do some grinding and clean up my welds... but I think it might work. Lastly, put some of the chrome bolts attaching the fenders to the radiator core.
wayno is offline
Old 02-03-2014, 09:49 PM   #56
wayno
Thanks man. Running 255/35 R20's - the plan is to make delmo specials out of them.
wayno is offline
Old 02-03-2014, 10:29 PM   #57
Lugnutz65
Lugnutz65's Avatar
Got my C50 grille out and stripped some paint. Bowtie gets removed and the badge will be relocated to the center area. I also put some POR-15 on the back of my grille support and original grille.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 02-04-2014, 12:04 PM   #58
endlessearth
endlessearth's Avatar
Notice anything unusual?
endlessearth is offline
Old 02-04-2014, 12:10 PM   #59
TJ's Chevy
TJ's Chevy's Avatar
You pulled the motor??? Painted the bay???? And I see some strange contraption cup on each side.....
TJ's Chevy is offline
Old 02-04-2014, 12:20 PM   #60
endlessearth
Cold air intake tubes. Rubber hoses will run from those tubes to a modified air cleaner assembly.
Old 02-04-2014, 04:27 PM   #61
TJ's Chevy
TJ's Chevy's Avatar
Nice addition...I might have to use that idea. lol.
Old 02-04-2014, 04:34 PM   #62
Lugnutz65
Lugnutz65's Avatar
Strange? Not at all! You, my friend, have not watched enough James Bond movies.
Cold air intake. That's what you are supposed to think! Hah! (evil chuckle comes on now if you had audio enhanced subscription). Those are cleverly disguised ROCKET LAUNCHERS! Get outa my way or else!
Old 02-04-2014, 06:24 PM   #63
TJ's Chevy
TJ's Chevy's Avatar
HAHAHHHAHAAHAHHAHAHAHAHHAHA!!!!!!!!!!!!!!!!!!!!!!!!!!!!! HEEHEEHEEEHEE!!!!!!! Good one!!!!!!!!!!!!!!!!!! Well...come to think of it....I never even heard of James Bond...probably cause I am to young.
Old 02-04-2014, 07:30 PM   #64
ChrisDollins
ChrisDollins's Avatar
Cool! I always thought that would look good! What are your plans for it? Painting, getting it chromed or leaving as is? Either way is cool. Want to see a pic on the truck.
Chris
ChrisDollins is offline
Old 02-04-2014, 07:55 PM   #65
Lugnutz65
Lugnutz65's Avatar
Chris
I pulled the grille from this bus. The chromed grille in the second photo is from a build here on the forum. Maggie's Custom - scroll down to post #444.
I have not decided if I will do the chrome or paint. Since I have not decided on the paint for the truck yet, all options are open, . . . . BUT I GOTTA SAY THAT CHROME REALLY LOOKS GREAT. I don't wanna copy, but if it looks good, it's hard to do something less.
Old 02-04-2014, 08:41 PM   #66
ChrisDollins
Holy cow that does look good! Wish I would've seen that before I ordered my normal one. I wouldn't worry about copying, what looks good, looks good! This is all I've done today. Snow day so built legos with the family. This is as close to 60-66 as I can get with what we have lol.
Chris
Old 02-05-2014, 04:04 AM   #67
pimpston65
pimpston65's Avatar
stripped, repaired,retaped the entire oem harness oh and saved $$$ by not needing to get a new harness
pimpston65 is offline
Old 02-05-2014, 04:06 AM   #68
pimpston65
pimpston65's Avatar
more harness pics
Old 02-05-2014, 04:09 AM   #69
pimpston65
pimpston65's Avatar
found some crusty AC44 plugs cheap, before and after a little elbow grease...
Old 02-05-2014, 04:11 AM   #70
pimpston65
pimpston65's Avatar
copper gasket of course
Old 02-05-2014, 04:44 AM   #71
markeb01
Senior Enthusiast
markeb01's Avatar
Resolved a couple of last minute bugs and wrapped up the Ron Francis rewire. I'm glad to have the truck back in service after most of 3 weeks down time.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 02-05-2014, 10:09 AM   #72
65Gregg
65Gregg's Avatar
Changed the oil and filter on mine. Every time I do this I cuss my long tube headers for being in the way of the filter but get over it as soon as I start the engine and listen to the exhaust. I decided to use a K&N oil filter this time because it has a 1" nut on the canister which will make removal easier on the next change.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 02-05-2014, 11:09 AM   #73
endlessearth
You found me out. Those are rocket tubes to be used for clearing busy intersections.
Old 02-05-2014, 09:33 PM   #74
pimpston65
pimpston65's Avatar
got me 2 yards of SMS's 65 C10 finest from the brown truck guy
Old 02-05-2014, 09:46 PM   #75
jayoldschool
Moderator
Very nice (and very expensive).
jayoldschool is offline
Closed Thread
