Old 02-03-2014, 06:12 PM   #1
ls1man
ls1man's Avatar
best under bed fuel tank 47/55 AD
Any links or suggestions appreciated.
ls1man is offline   Reply With Quote
Old 02-03-2014, 06:21 PM   #2
ChevyGearHeads
Re: best under bed fuel tank 47/55 AD
me and my son did a 80 chevy pickup the video is on chevygearheads youtube hope this help's
Paul
'68 C10 327/TH350
LWB
ChevyGearHeads is offline   Reply With Quote
Old 02-03-2014, 06:46 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
There have been several discussions lately about tanks. Do you want a side fill, rear fill, bed fill, 18 gals, more than 18, EFI or carbed motor, I did a 18 gal. Camaro EFI tank with a rear fill. There are aluminum ones that fit between the rear cross members. So really the best tank is the one that fits your budget and truck.
Old 02-03-2014, 07:04 PM   #4
ls1man
ls1man's Avatar
Something cheap, i would like a bed fill. Its efi but may use external high pressure pump.
Old 02-03-2014, 07:50 PM   #5
not2oldchevy
Late 80's 2 door s10 blazer. Less than $100 rockauto. That is what I used on my 53 LS.
not2oldchevy is offline   Reply With Quote
Old 02-03-2014, 10:56 PM   #6
PurdueSD
PurdueSD's Avatar
External pumps are loud and finicky about low fuel levels sometimes. I'd suggest finding an oem style replacement tank/ with an in tank oem pump/ sender that fits. It will be cheaper and work like it was designed for it, because it was.
For my TBI 350 I found a s10 tank/sender/pump from the same era that fit well. late 80s s10 blazer. I think I have about a hundred bucks in the set up...all new parts from rock auto. You need one from a later donor that puts out efi pressure.
My Lost and Forgotten build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=442712
PurdueSD is offline   Reply With Quote
Old 02-04-2014, 11:03 AM   #7
whitedog76
The 47-48 and 47-53 panel truck tanks are something to look in to. You can get the tank out of the cab. They won't work on 54/55 trucks.
I never have liked the tanks that you have to fill in the bed floor.
I like the blazer tank, how do you fill it though?
I've heard of guys using mustang tanks behind the axle of AD trucks.
I kind of thought the late 40's/early 50's Chevy car tanks might be worthwhile looking into. You could probably fill them from the side.
http://www.classiccarautoparts.com/gastanks.html
whitedog76 is offline   Reply With Quote
Old 02-04-2014, 07:00 PM   #8
D-man313
D-man313's Avatar
I used a 16 gal poly tank from speedway motors. Topfill, fill through the bed. Bought the fuel tank mounting straps. Welded some tubing to the frame crossmember, welded the top half of the strap to the tubing and bolt the tank in. Im on a s10 frame tho too.
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where
D-man313 is offline   Reply With Quote
Old 02-09-2014, 12:49 PM   #9
gag1025
An external electric fuel pump is not loud and noisy if you isolate it from the frame you are attaching it to using rubber isolation strips as well as rubber grommets for the bolts and screws. We constructed a small metal mounting platform (which we welded to the frame) and attached the fuel pump to it (which we isolated from the mounting platform using rubber strips and rubber grommets). Photos tell the complete story.
1953 Chevy 3 Window Truck 3100 Series
gag1025 is offline   Reply With Quote
Old 02-09-2014, 12:56 PM   #10
gag1025
Forgot to add my fuel tank photo. It came from Docs Kustom Tanks.
