Old 02-05-2014, 04:58 PM   #1
Bagged1972
Newer seat in a 67-72 truck
I was wondering if anybody has put a 99-07 silverado seat in one of these trucks. If so how hard was it and can I see some pics of it installed. I was thinking about this cause the seat belts is made into the seat.
Bagged1972 is offline   Reply With Quote
Old 02-05-2014, 05:11 PM   #2
leftybass209
leftybass209's Avatar
Re: Newer seat in a 67-72 truck
There's some threads here with those seats. Try and do a search. Fit is tight if you have an in cab tank. Good luck.
leftybass209 is offline   Reply With Quote
Old 02-05-2014, 05:25 PM   #3
Bagged1972
Thanks man well I'm kinda short so I don't think that would effect me to much
Old 02-05-2014, 05:39 PM   #4
dylanprice00
the seats i have are out of a 2006 extended cab chevy we just removed the old seat and straps and got bolts with wide washers and drilled the holes and bolted them down the one problem i had was being six foot five and needing leg room. and the little hump in the middle of the cab was messing with mounting the front bolts and we had to pull the tracks out past the hump to get a flat surface and i'm having trouble posting a picture with it im fairly new to the forum and have not figured it out yet
dylanprice00 is offline   Reply With Quote
Old 02-05-2014, 05:54 PM   #5
Bagged1972
I can't see the image so I take it you removed the fuel tank
Old 02-05-2014, 06:00 PM   #6
dylanprice00
Old 02-05-2014, 06:31 PM   #7
Bagged1972
Man that's badass I was thinking about doing something similar to the marker light on my 72 but I figured it was to much trouble than what it's worth how hard was is to do that? And the seat looks good sitting in there I think that's the way I will go.
Old 02-05-2014, 06:50 PM   #8
dylanprice00
My dad fabricated the bracket for the light with a newer chevy/gmc gas door arm and the only problem is some gas stations pump too much fuel and the breather will shut it off but I go to a station that does it a little slower and is fine if it's a Dailey driver I recommend the bed floor filler
Old 02-05-2014, 07:40 PM   #9
'71 Chevy
Got seats out of an '02 Chevy in mine. Gas tank is behind the seat. I'm 6' 4" and I have enough room. I will see if I can get some pics. of them for you.
'71 Chevy is offline   Reply With Quote
Old 02-05-2014, 07:45 PM   #10
Bagged1972
I'm not build a DD just a weekend cruiser just something to have fun with
Old 02-05-2014, 07:46 PM   #11
Bagged1972
Cool deal
Old 02-05-2014, 08:34 PM   #12
sambudo
sambudo's Avatar
I'm ijnterested in seeing pictures
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 02-06-2014, 01:23 AM   #13
70blackfish
me too
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 02-06-2014, 05:15 PM   #14
dylanprice00
how? my knees are just about touching my gauge cluster and shifter handle plus my tank is under the bed...
Old 02-06-2014, 08:00 PM   #15
'71 Chevy
Flexible...I guess. Its only about 2" inches closer to the steering wheel than my '89 Chevy with the seat all the way back. With the tank gone you could probably gain 4"-5"?
Old 02-06-2014, 08:01 PM   #16
'71 Chevy
I will get pics. It's just to cold right now.
Old 02-06-2014, 09:44 PM   #17
hugger6933
You really don't gain as much as you would hope with the tank being gone. The seat comes into contact with the cab before anything else so little room is gained for the legroom but much is gained as far as storage for stuff behind the seat. I have tried the later seats in the truck but they just were not for me. I am on the large side, I am of heavy build thick frame, and I am 6'3 375lbs and the seats just were not the best solution for me. In my 68 GMC I have buddy buckets and a tilt column that is "pushed" all the way down and that helps a lot. But with the 99-07 seats in the 70 Chevy with standard column it just didn't work for me, so after the build it will have tilt and buckets so at least I can drive it before someone else owns it. Jim
hugger6933 is offline   Reply With Quote
Old 02-07-2014, 06:38 PM   #18
elektrik
Foolish Mortal
elektrik's Avatar
I got '95 Silverado seats in mine...love it...SOOO comfortable...and power Lumbar to boot
elektrik is offline   Reply With Quote
Old 02-08-2014, 11:28 AM   #19
greg peterburs
greg peterburs's Avatar
I put 2002 chevy Silverado seats in my 71 chevy sb. Not too hard to install. I can send you some pics thru e-mail, but can't seem to post on this site.
greg peterburs is offline   Reply With Quote
Old 02-08-2014, 12:19 PM   #20
463
463's Avatar
here is a link http://67-72chevytrucks.com/vboard/s...d.php?t=605928
Trueman
463 is offline   Reply With Quote
