Old 02-08-2014, 11:22 AM   #1
eastxbbqman
eastxbbqman's Avatar
4bt conversion
Been looking at some different 4bt swaps that are in various cars and trucks online. I would really like some input from people that have actually done this. Is the shaking that bad? What trannys can I use? Some of them that are for sale already have ford or gm 4 spds behind them. I can live with some rough edges. I do drive a 42 year old truck, not looking for a smooth as silk ride. My truck is a 71 lwb 1/2 ton 350 350 2wd. Thanks for any help y'all can send this way.
eastxbbqman is offline   Reply With Quote
Old 02-08-2014, 11:37 PM   #2
Ackattack
Ackattack's Avatar
Re: 4bt conversion
Try here for some real world experience:
http://www.4btswaps.com/forum/forum.php
Ackattack is offline   Reply With Quote
Old 02-09-2014, 11:59 AM   #3
ryanroo
ryanroo's Avatar
Re: 4bt conversion
4btswaps is a good place for info.
i have been around one or two of these and performed the swap myself in a 92ish jeep cherokee. the shake is mostly at shutdown and if you are idling in gear with an auto. they they can shake pretty good. driving down the road, they are nice and smooth.
transmission choices are pretty wide open. they came with GM transmissions both manual and auto. they came with ford transmissions behind them as well. any adapter plate that was used on a 6BT can be used on a 4bt. that opens up all of the dodge diesel transmissions to you and any of the SAE pattern transmissions that were behind them in industrial applications.
Destroked is a company that makes a bunch of different flywheel housing/adapter plates that opens up a bunch of other options as well. they have a GM standard bell pattern adapter that takes the tilt out of the OEM ones that step van engines had as well.
i wouldnt be scared to put one in anything that a 6bt wouldnt fit in.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-09-2014, 06:13 PM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 4bt conversion
You can also add a damper to the crank instead of just a pulley yo help minimize the shake. These are great engines.
Ryan
1969 Chevy milk truck
Old 02-09-2014, 09:40 PM   #5
1972RedNeck
1972RedNeck's Avatar
Re: 4bt conversion
Get one with the adapter to a GM tranny. Make sure you get a flywheel too. If your truck has a manual in it, you can just bolt the engine right to transmission, make two new motor mounts, and be done. It's quite an easy swap.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-10-2014, 10:52 PM   #6
Dieselwrencher
Re: 4bt conversion
Just be sure you regear your rear end if it's geared low other wise all that work will be for nothing.
Ryan
Old 02-11-2014, 06:17 PM   #7
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: 4bt conversion
I agree, I had a 4bt in my old 86 Ford 3/4 ton with a T-19 and 4.10 rear end...it was great around town but didn't do well on the highway. An overdrive would have been nice.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-12-2014, 06:45 PM   #8
eastxbbqman
Re: 4bt conversion
Thanks. I'm trying to learn from others mistakes before I attempt this.
Old 02-13-2014, 09:23 AM   #9
gerfunken
gerfunken's Avatar
Re: 4bt conversion
I see, you're just trying to be different.
I thought I was doing the same thing, researching, asking questions, etc. While I ended up not repeating the mistakes of those I asked, I created a whole new set of mistakes that they couldn't foresee.... But, mistakes aside, this board and a couple of others have been great as resources and for answering questions that I've had along the way.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
