Old 02-08-2014, 07:51 PM   #1
69Rumbler
69Rumbler's Avatar
Disc Brake kits 8 lugs
What kits are you guys using ?? For 8 lug disc brakes
1969 C20 CUSTOM "RUMBLEr"
69Rumbler is offline   Reply With Quote
Old 02-08-2014, 08:19 PM   #2
ZombiePopper
ZombiePopper's Avatar
Re: Disc Brake kits 8 lugs
I'm curious about this also (for the rear axle 4x4)
ZombiePopper is offline   Reply With Quote
Old 02-08-2014, 08:57 PM   #3
SS Tim
SS Tim's Avatar
Front is a straight bolt on of factory parts up through 91 in some cases.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
Rear discs are more of a problem. If you find a C20/30 kit with a real park brake and not a car rated caliper let me know.
SS Tim is offline   Reply With Quote
Old 02-08-2014, 09:20 PM   #4
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Only did fronts on my C20. I researched both CPP and POL I decided to use Performance Online.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-08-2014, 09:22 PM   #5
budnikguy
budnikguy's Avatar
If you are speaking of front disc brakes, i have a complete swap out from a 71 3/4 ton that would do the job for ya..and I am local to you...
budnikguy is offline   Reply With Quote
Old 02-08-2014, 09:22 PM   #6
69Rumbler
69Rumbler's Avatar
How they working ... Any complaints ?
Old 02-08-2014, 09:27 PM   #7
69Rumbler
69Rumbler's Avatar
Yea I am I just PM you !
Old 02-08-2014, 09:52 PM   #8
Aussie Ol' Blue
Aussie Ol' Blue's Avatar
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
I'm planning on doing this conversion as well but have heard that there is a difference in the bolt sizes between the disc and old drums. Is that actually the case? 70/c20
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY!
IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE!
Aussie Ol' Blue is offline   Reply With Quote
Old 02-08-2014, 10:30 PM   #9
ZombiePopper
This is what I've heard,
Anyone offer a rear disc kit for c or k 20's/30's?
Old 02-08-2014, 10:37 PM   #10
72 K20
72 K20's Avatar
Here's a couple of links that might help !
http://www.ruffstuffspecialties.com/...g/EHO5272.html
http://blackbirdscustomtrucks.com/index7.html
72 K20 is offline   Reply With Quote
Old 02-08-2014, 11:27 PM   #11
colgad
colgad's Avatar
I used the BlackBird ones and the kit is simple to install. All bolt on.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 02-08-2014, 11:59 PM   #12
derotoreut
derotoreut's Avatar
Did you use on front, rear or both? Curious about the rear. Thanks.
~ Dan
Old 02-09-2014, 12:09 AM   #13
jocko
jocko's Avatar
I'd like more details also! Pics, etc. Did ya go with the integral parking brake caliper? If so, any issues you might see with it holding a truck with a camper? Did you need to add an adjustable prop valve to balance front / rear - or was the factory distrib block ok?? (I assume you'd have to have an adj valve). Very interested.
Old 02-09-2014, 10:48 AM   #14
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Heres one I put together myself on the Eaton HO52 using the brackets from NW fabworks. If doing again, I would find brackets with holes already in that allow the caliper to mount at the 3/9 o'clock position. I used 78 Eldorado calipers and its true they are from a car, but those cars were huge and weighed what, 5000 lbs? Compared to the smallish 11x2 that was stock on the eaton, I cant believe I lost much if any stopping power. Caveat is I haven't had it out on the road yet, but should in a couple days.
The calipers are the same size as the stock front K20 ones but the piston is a little smaller, which is ok since the rear shouldn't do as much work as the front.
Parking brake cable brackets I made to use stock parking brake stuff:
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
