Old 02-09-2014, 02:33 AM   #1
Iceburgh
Iceburgh's Avatar
Anyone recommend a radiator?
Going in a '53, first time with a LS motor. Curious if anyone makes a good Rad that will cool and easy to install with in and out in a easy way to route the hoses.
Also I hear some people talk about the LS motor needing a steam port other say no...
Iceburgh is offline   Reply With Quote
Old 02-09-2014, 05:42 AM   #2
truckdude239
truckdude239's Avatar
Re: Anyone recommend a radiator?
I used a Griffin rad from summit ra ing in my 71 $247.00
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-09-2014, 10:35 AM   #3
mooseknuckles
mooseknuckles's Avatar
griffin.......the steam port needs to be run somewhere, but not necessarily to the rad...
mooseknuckles is offline   Reply With Quote
Old 02-09-2014, 01:00 PM   #4
jamesjones
Freakin Awesome!
jamesjones's Avatar
I'm leaning towards this one...
http://www.summitracing.com/parts/gr...del/c10-pickup
with the built in trans cooler and some Ford Windstar EFans.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 02-09-2014, 01:07 PM   #5
Hart_Rod
Hart_Rod's Avatar
Entropy.
Hart_Rod is offline   Reply With Quote
Old 02-09-2014, 01:17 PM   #6
littlevictories
im going with this in my '66 (gotta take the radiator shroud off the core support)
Griffin Radiator 8-70009-LS Dominator Series... Griffin Radiator 8-70009-LS Dominator Series...
easier to run the hoses both on the passenger side and gets you a double pass.
tranny cooler on the driver side though, which is kindof a bummer.
also the mounting flanges will make my fit a lot easier.
littlevictories is offline   Reply With Quote
Old 02-09-2014, 01:27 PM   #7
Jon01
Jon01's Avatar
The stock radiator will keep it cool just fine.
I don't have a steam port on mine, I just tapped the top of the water pump and connected a 1/4" hose to it and the crossover tube between the front of the heads.
Never had a heating issue last summer driving it in 100+* temps.
Jon01 is offline   Reply With Quote
Old 02-09-2014, 06:27 PM   #8
Clyde65
Clyde65's Avatar
I have a champion aluminum rad. Inexpensive and cools to 650 hp
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-09-2014, 09:30 PM   #9
truckdude239
http://m.summitracing.com/parts/gri-8-00013-ls is whwt i got
David fuller
2000 Tahoe 5.3l 378
Old 02-09-2014, 10:17 PM   #10
Andy4639
Old member
Andy4639's Avatar
Talking Re: Anyone recommend a radiator?
I would use the factory one that you have. Take it have it cleaned and roded out good and go with it. Drill and tap the water pump and tie it into the cross over lines as most do. You can see mine in the picture.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-10-2014, 12:39 AM   #11
Root2812
Root2812's Avatar
Since its going in a 1953 I would not reuse the stock radiator. I'm doing the same swap. A lot of the guys over in the 47-59 section are going with Champion radiators. They can be had for around $200 for it and its made from aluminum. Your old radiator kept the 216 cool but its probably in rough shape. By the time you pay to have it rebuilt you could just buy the Champion one.
As for the steam port, you can tap the top of the radiator (by upper hose connection and zip tie your steam tube to the upper hose) or just tap the top on the water pump and hook it up. Its not a big deal and you should not sweat about it.
My 1950 Chevy build
Last edited by Root2812; 02-10-2014 at 12:43 AM. Reason: Added the "Not" in the last sentance.
Root2812 is offline   Reply With Quote
Old 02-10-2014, 11:55 AM   #12
SparkyRnD
SparkyRnD's Avatar
we don't have a pattern yet for the 47-59 models, but if we can get an original, we can build one easily (and would include a discount for the person test fitting). For the steam port, I would recommend running it to the radiator. That way if your water pump fails while on a trip, you can easily swap it in the parking lot without having to also drill and tap the waterpump.
For the LS radiators, we put the correct size inlet and outlet on the passenger side, and include a steam port and trans cooler at no additional charge on all of our radiators (we are a supporting vendor here), and all of our radiators are made here in the USA
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 02-14-2014, 01:51 AM   #13
First c10
First c10's Avatar
This is a champion with 2-14" fans and aluminum shroud. I got it on eBay
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
