![]() Join Date: May 2002
Wheel Bearing/Hub Assembly
Hey Everyone,
My 2wd '69 has already been converted to 71/72 disc brakes. I need to replace the brake pads, and possibly turn down the rotors, but I digress. Has anyone converted from the stock style rotors (bearings/wheel lugs in the rotor), to a wheel bearing and hub assembly (rotors slide onto the lugs). If you have, what did you use, and were any modifications required to any of the other parts? I'd like to be able to do this when I do the brake job.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
![]() Join Date: Sep 2005
Re: Wheel Bearing/Hub Assembly
My quedstion would be why? Stock bearings 5.99 each 20 buxs for both sides. Hub asmbley 69.99 one side
Why not? Wouldn't have to re-pack bearings every time, or over/under tighten the preload on the bearings each and every time. Easier to replace the rotors, too.
