Old 02-11-2014, 01:58 PM   #1
hardwaycooke
hardwaycooke's Avatar
To Tape or Not To Tape...Please help...
I am replacing my heater hose manifold adapter with a new one. Old one did not have Teflon tape on it. I am also replacing the water pump plug. It Is Teflon taped.
Do I need to tape them??
hardwaycooke is offline   Reply With Quote
Old 02-11-2014, 02:05 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: To Tape or Not To Tape...Please help...
I would put tape or some kind of sealer on those. The temp sender is the one you don't want sealer on
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-11-2014, 02:06 PM   #3
leftybass209
leftybass209's Avatar
There is no harm in taping it correctly, only the added benefit of no leakage. In the end, if you didn't want it to "show", you could always take a razor blade and run around the excess, for a clean finish. In my mind, benefits without repercussions are a thumbs up! Good luck and hopefully others will share some insight as well.
leftybass209 is offline   Reply With Quote
Old 02-11-2014, 03:22 PM   #4
truckster
truckster's Avatar
Third vote in favor of tape. I recommend the heavy-duty type rated for gas and oil - it's usually yellow.
truckster is offline   Reply With Quote
Old 02-11-2014, 05:42 PM   #5
Tinkermc
rather be safe than sorry,. I'd tape.
Tinkermc is offline   Reply With Quote
Old 02-11-2014, 06:01 PM   #6
westong
yep, I use the yellow gas tape on anything that is going to see any temps above 125deg. It is 4 times the cost of the white but i have never had a leak using it.
westong is offline   Reply With Quote
