Old 02-11-2014, 06:57 PM   #1
54blackhornet
54blackhornet's Avatar
292 Heater Hose Routing ?
Hooking up a heater in my 68 GMC with a 292, any one have a picture of the hose routing ? Thanks
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 02-11-2014, 10:18 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 292 Heater Hose Routing ?
This maybe? #1
Or this? #2
I'm not sure it makes a difference on the six but maybe someone that is sharper than me on them will chime in....
LockDoc
Leon
Old 02-11-2014, 10:24 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
I might have a shot...
Old 02-11-2014, 10:42 PM   #4
pritch
pritch's Avatar
The question is, I think, is should the water pump up through the core or down through the core. I'm sure there is a correct way, but I doubt if it makes much difference overall.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 02-11-2014, 11:48 PM   #5
SS Tim
SS Tim's Avatar
The correct flow is from the t-stat housing to the lower heater core nipple (the inlet). Then it runs from the upper heater core nipple (the outlet) to the water pump. While I am not positive, IIRC the HD cooling, automatic or A/C trucks returned to the radiator as did V-8s.
The reason it flows this way (bottom up) is to purge trapped air (pockets) from the heater core which would cause it to be cool.
SS Tim is offline   Reply With Quote
Old 02-12-2014, 12:11 PM   #6
54blackhornet
Thank you to all for the information ! Another question about the core position in its housing ? Is the 3/4 connection the inlet or the outlet ? My wife is yelling about the heater parts all over the kitchen table !.......
71 C-20
07 Magnum RT AWD
Old 02-12-2014, 12:15 PM   #7
Wrenchbender Ret
The 3/4 " tube is the outlet.
Wrenchbender Ret is offline   Reply With Quote
Old 11-13-2020, 07:05 PM   #8
Asshat
Asshat's Avatar
Is this correct?
1.to small inlet of core
2.to large outlet of core
3. to radiator
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 11-13-2020, 07:10 PM   #9
CarolinaHD
Moderator
CarolinaHD's Avatar
Originally Posted by Asshat View Post
Is this correct?
3. to radiator
Correct, here is my 67 c50 for reference.
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 11-13-2020, 07:21 PM   #10
Asshat
Asshat's Avatar
Ok. Thanks.
The only difference, mine has only one threaded port on the passenger side of the thermostat.
292, 4-speed
Old 11-13-2020, 09:25 PM   #11
CarolinaHD
Moderator
CarolinaHD's Avatar
Here are the differences over the years in thermostat housings and water pumps. The pics are not mine*
Alex
