Old 02-12-2014, 03:16 PM   #26
mechanixman
mechanixman's Avatar
Re: Starting my new build
Looks good! So what did you do thattl was upsetting?....
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline   Reply With Quote
Old 02-12-2014, 03:30 PM   #27
speesh
speesh's Avatar
This is what I like about this site... no matter what you want to do to your truck, there is always supportive people saying "yeah, you can do it!" and other people saying "here is how".
Not like most other websites with flame wars, arguments, etc. This is the most mature of all the automotive websites I have read. (Stovebolt.com is pretty grown up too though.)
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban
Endeavor to persevere.
"All of a sudden, I'm the old timer!" Some old timer on American Pickers.
speesh is offline   Reply With Quote
Old 02-12-2014, 08:54 PM   #28
sparks54
sparks54's Avatar
I like what you are doing to your truck and it looks like you are off to a good start on things. I will be following your post..... keep your pictures coming.
QUARTER TURN BEFORE IT SNAPS.....
1954 Chevy Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=584702
sparks54 is offline   Reply With Quote
Old 02-12-2014, 10:39 PM   #29
T-P Auto
Hello Again:
To mechanicman;
I really thought someone would be upset with cutting the bed where I did to fit the frame. ? ? ?
Got some more pic to share.
Got the ugly rusty side metal off.
Took the time to set the bed on the frame to see what it looks like.
Still need to build the New front part of the bed.
Going to use panels i keep frome the Van i stripped for parts on this project.
Making a 3/4' frame work then covering it on both sides.
I'm really get a lot of fab time on this project.
Set about fabing the cab mounts, useing the cab mounts that I cut off the frame.
Will take some pic when I have the bed n cab off to weld up the mounts.
Set the bed on the frame to get it level an aligned.
Looking at about 1" cab to bed clearence,
I like the look of how the bed set, How I have to work on the fenders? ? ?
It looks like I'm not going to be doing much on the project for the next couple of day,
Have to see the dr tomorrow,then have to work on a 82 dodge pu,friday n sat, Have to do the gas tank, exhaust muffler, install oil pressure n water temp gauge in n under the dash, also have to repkace the heater control fan switch.
This will give me some cash to work on my project.
I have also enclode a NEW pi of the next project I have to tackle(1949 Ford 2,5 ton)
It has been setting up for like 15 yrs, the man wants to get it running n brakes working. When I get it working I'm going to drive it to coffee one morning,
It has a new style 300 6cyl in it. Will be standing on my head to work on this beast,
How the pics.
T-P Auto is offline   Reply With Quote
Old 02-17-2014, 09:24 PM   #30
T-P Auto
Hello again;
Got to work on the project over the week end n today.
I worked on the bed area over the week end.
Had to make a couple of frame to bed mounts (both ft n rear)- (see pics).
Had to make a NEW ft bed pan (between cab n bed) - (see pic)
set the fender on for mock up- ugly
Reset fender on bed (see chald mark)
Looking to cut the fenders to fit the NEW mock up
cut fender on the marks (see pic)
Just wonder what you all think of cutting the fender to fit?????
Old 02-17-2014, 09:31 PM   #31
T-P Auto
Hi again;
More pic of the week end work;
Old 02-17-2014, 10:09 PM   #32
T-P Auto
Hello again;
I have been working on my 1950 chevy rod.
I"m going to have several parts for sale.
1 complete gas tank w filler neck(behind seat)
Hood hinges (cab mount n hood spring mount) both sides
full seat frame
Old 02-21-2014, 10:05 PM   #33
T-P Auto
Hi again;
It has been a few days since I posted anything.
Been busy getting the bed mounted,
lowering the fenders,clearence on wheels n center opening.
marked inter fender/bed for cutting
next up is the brake assy,
steering wheel installed,
then trying to mock up a trans cover ??
trans cover is really giving me (deep thought) trouble.
have posted pic to go along with post
Old 03-05-2014, 11:49 PM   #34
T-P Auto
Hi Again:
It has been a few days since my last up date.
I had to take a brake from the project.
Had some WORK(paying) come into the shop.
Hope to get back on the project again later this week or first of next week.
Old 03-20-2014, 09:04 PM   #35
T-P Auto
Hello Again:
Want to give a shout out to "oldman3"
for the great info on the bear claw latches.
Will keep the info forlater date upgrade to the doors.
Here are some NEW pic of what has gotten done.
Got the cab bolted on totally.
Got the bed squared up n bolted down.
Got the driver seat fitted with power adjustment.
Got the pass seat set up on a van type pedestle,able to remove the whole system.
Working on the steering wheel n power brake system.
Having problem with clearence on the brake pedal n steering wheel assy.
"see pic"
Looks like I'm going to have to enlarge the hole on firewall for the steering wheel assy to get a stright shot thur the fire wall.
Sure glad the hole saw didn't work, have to move the brake pedal assy over to the trans about 4",for the pedal to clear.
Got the door hinges bolt holes tapped n cleaned out n the pass door hung.(no pic)
I think that about cover what I have gotten done this week so far.
Thanks all;
Old 03-31-2014, 11:32 PM   #36
T-P Auto
Hello again:
I have started a NEW post on projects n builds,
called (Frankenstine)
hope you all will enjoy the pic n the thoughts I share.
