02-13-2014, 01:48 PM | #26 |
Re: Will BBK headers for a 2010 Camaro fit a '72 Chevy C10 4.8 swap?
There are 2 jeep tanks in 91- one is baffled for efi. Just to FYI.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-24-2014, 04:19 PM | #27 |
Drove it a couple miles and realized the speedometer isn't working, but everything else is OK. Now it's time for dyno tuning:
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
02-24-2014, 04:26 PM | #28 |
It's alsways something.....
Matt, is that a dyno hooked to the hub?
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
02-24-2014, 04:58 PM | #29 |
Correct - that's a Dynapack hub dyno with the covers off, as the covers wouldn't clear the bed.
03-05-2014, 11:18 AM | #30 |
Found I hadn't filled the coolant properly - d'oh! Oh well, looks like nothing's damaged and it's full now.
The transmission is slipping a bit if you load it up for a couple minutes, and that's prevented me from getting a full tune. Some other issues I need to sort out: The cab smells like gas and it appears the fuel level sending unit isn't sealed properly. Need to get that right and replace any remaining rubber parts in there with new ones. Long term solution will be that under-bed gas tank. Need to hook up the temperature gauge and fix whatever I did wrong with the speedometer. The wideband O2 sensor isn't working - I think I may have damaged its wiring when I dropped the exhaust to get a new brake line in there, as the factory ones were so close I was afraid of boiling the brake fluid. Need to readjust the parking brake. Some miscellaneous wire tidying up is in order. Overall, the swap itself is pretty complete. The truck could use some other work too - maybe new front coils at the very least...
03-05-2014, 12:13 PM | #31 |
Still Learning
Looks like a very nice project. I have a 4.8 in my project too.
03-06-2014, 04:05 PM | #32 |
Nice job on the truck. I was wondering where you got the manifold flanges for the exhaust manifolds. A friend of mine has a set of 2010 camaro manifolds but no flanges for it. I was thinking about buying them for my build. If i can find the flanges. I saw where you swapped to a cable operated throttle body what is the advantage?
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 Last edited by dwcardfan; 03-06-2014 at 04:18 PM. |
03-06-2014, 04:30 PM | #33 | ||
03-06-2014, 05:06 PM | #34 |
Thanks Matt. I have a cable throttle body and was thinking about swapping to dbw. I thought it might be easier to mount pedal and not have to set up cable. How much trouble was it?
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
03-07-2014, 09:10 AM | #35 |
Compared to other parts of the swap, the cable operated throttle was easy. I used my stock gas pedal and a 3' mountain bike brake cable for the throttle cable. Made a bracket on the manifold (since the engine was originally DBW) out of some aluminum angle extrusion and a rubber isolated clip. To anchor it at the firewall, I cut the end off the stock throttle cable, drilled a hole, and glued the end of the bike brake cable into it.
03-07-2014, 09:15 AM | #36 |
Thanks Matt.
03-07-2014, 09:42 AM | #37 | ||
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-07-2014, 10:04 AM | #38 |
Thanks Hart Rod! I have a 2000 silverado that was wrecked and have the complete set up. DBC I will be using everything but a new harness. Thanks for all the help guys. It makes it a lot easier with all this information.
06-11-2014, 05:35 PM | #39 |
I love the fuel pump install. What did you do for a return line? Any fuel starvation problems due to not having baffling?
I have a 5.3 sitting in my garage with a blown head gasket. I am in the process of fixing up the engine and getting it ready to install. I am on a tight budget and your fuel system seems to be the answer to my prayers. At least temporarily. Pics of your return line set up would be great if you have them.
"Live, Love, Build cool s***" Jesse Chapman, 2013 My Truck.. http://67-72chevytrucks.com/vboard/s...d.php?t=567219 |
06-11-2014, 06:42 PM | #40 |
06-12-2014, 10:50 AM | #41 | |
I've heard the pump sputter on hard turns below 1/8 tank. Other than that, the biggest problem was sealing the vapors out of the cab, but that seems to be solved.
06-12-2014, 01:01 PM | #42 | |
Thanks for this-may need it!
07-02-2014, 10:00 PM | #43 |
I'm still leaning towards a stock sbc for mine, but you made this LS swap look easy and straightforward with great documentation and good tips to keep the cost under control. Nice work!
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
07-03-2014, 08:22 AM | #44 |
Thank you. This wasn't exactly a straight bolt in, but the problems tended to be things that can be solved with a little plugging away. If I had to do things over again, I would have put the engine stands in the V8 location, giving up the possibility of using the truck A/C compressor location in the future but trading that for better exhaust clearance.
09-30-2014, 03:23 PM | #45 |
I am doing the same fuel pump setup you are. The only issue I am having now is how I want to wire up my fuel pump. How did you do yours?
09-30-2014, 03:42 PM | #46 |
I finally ended up using gromets and through bolts with ring terminals on each end.
09-30-2014, 03:55 PM | #47 |
Yeah, that was my plan. I was just making sure you didn't have some other trick up your sleeves. Getting close to having my 5.3L in my truck. Can't wait.
10-02-2014, 04:52 PM | #48 | |
Really great build and write-up! Nice to see someone else from GA on the forum.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
10-03-2014, 08:06 AM | #49 |
Now I had the TH350 break down - it'll go in reverse, but not forward. Again, figured I might as well upgrade while replacing it, so I've picked up a used 4L60E. I'll get to work on that swap in the next couple weeks.
10-03-2014, 09:56 PM | #50 |
I saw on another thread you mentioned the Microsquirt being used as a trans controller. Is that the game plan for the 4l60e?
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
