02-13-2014, 11:41 PM | #1 |
Solid motor mounts for 67-71 big block
Does anyone know if there's such a thing as solid mounts for the 67-71 big block motor stands?
02-13-2014, 11:54 PM | #2 | ||
"I ain't nobody, dork."
Re: Solid motor mounts for 67-71 big block
Moroso might make them. More of a drag racing only type of deal.
Energy Suspention or Prothane makes Urethane motor mounts for these trucks. Gary
02-14-2014, 12:18 AM | #3 |
If you use solid motor mounts, you need to use a solid transmission mount. Then you go to your dentist and have him pull all your teeth out so you don't vibrate your fillings out. I guess you could keep any that don't have fillings.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
02-14-2014, 12:34 AM | #4 |
You should never use a solid transmission mount with solid motor mounts. either one or the other. I don't really want to use solid mounts on the engine, but I'm also a bit weary using small block motor mounts with the big block. I have the factory big block motor stands for a 67-71, but would need to use a large thick washer on the bolt so it doesn't pull through the larger hole in the big block stands using the small block rubber mounts. I just don't want the 454 ripping out mounts regularly and the correct big block mounts are really expensive and harder to come by
02-14-2014, 01:00 AM | #5 |
You can use urethane trans mounts, but not rubber with solid motor mounts. At least that's what transmission makers recommend. Why not just buy the correct mounts? I have mine tied down in case I break a mount, but haven't in the last few decades.
02-14-2014, 01:08 AM | #6 |
18 Till I Die
I have been there. Use a grade 8 bolt/Washer and I fabricated a square block from flatbar and drilled a hole in it. 1/4" Thick I believe, Measure the stand backside what size fits I don't remember. Never had a problem. I used GM mounts and was gonna go with Polyurethane someday...
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
02-14-2014, 01:09 AM | #7 |
The correct mounts are hard to find and $80- $100 a piece. Might just as well buy good performance ones if I'm going to spend that kind of money. I have a urathane mount for the Tremec already. Might chance a small block mount or maybe a urathane small block mount
02-14-2014, 01:13 AM | #8 |
The Older Generation
There is a thread or two on here about using the '73 up clam shell mounts on the '69-'72 big blocks. If I remember right it isn't too involved. Try the FAQ forum. LockDoc
02-14-2014, 01:24 AM | #9 |
The Truck Shop sells 67-71 BBC mount kits for $86.00 a side.
Ecklers carries urethane mounts in both the OEM and captive styles for about the same price just not sure how complete of a kit it is. Since you already have the 71 down stands and a manual trans (?), seems like an easy decision to me.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-14-2014, 02:00 AM | #10 |
Moderator
I would just buy the correct ones. They are pricey but will accomplish your goal. All the 40 year old originals I have come across were fit for continued use, so new rubber ones will probably outlast you, lol. You can also post a want to buy ad on the parts board and I'll bet you can find some OEM used for less.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
