Old 02-13-2014, 12:36 AM   #1
Skunksmash
Skunksmash's Avatar
Weird steering mod... kind of
So this guy puts a jeep steering shaft in, to help with all that play that these trucks are so bad about. According to him its some kind of big help. Thoughts?
https://www.youtube.com/watch?v=H9C4RdvjPNQ
Skunksmash is offline   Reply With Quote
Old 02-13-2014, 01:01 AM   #2
Squareforceone
Squareforceone's Avatar
Re: Weird steering mod... kind of
been discussed on here plenty just use the search bar you'll find all you need to know
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 02-13-2014, 03:37 PM   #3
dman1982
dman1982's Avatar
this is very interesting....does it really help that much???? i might just try this
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 02-13-2014, 04:10 PM   #4
Cherub
Cherub's Avatar
yea if you have a bum rag joint you will notice it. Its a cheap mod i do to my c10s
Cherub is offline   Reply With Quote
Old 02-13-2014, 10:19 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can likely replace your rag joint cheaper, unless someone just gives you the shaft for free.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-14-2014, 12:57 AM   #6
1774btcrew
1774btcrew's Avatar
You can buy the jeep shafts at the wrecking yard for $15-30 so they are actually pretty cheap.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 02-14-2014, 07:35 AM   #7
Tx Firefighter
http://67-72chevytrucks.com/vboard/s...d.php?t=614332
Old 02-14-2014, 01:21 PM   #8
Billy81
Billy81's Avatar
The jeep steering shaft mod wouldn't work on my 76 C20 it would not fit on the input shaft on the steering box. I did not know that some of the steering boxes used different sized input shafts with different spline counts. Some are 3/4" 30 spline but most are 13/16" 36 spline. My 76 had the 3/4" 30 and the jeep shaft was way too big.
Billy81 is offline   Reply With Quote
Old 02-14-2014, 02:07 PM   #9
Jonboy
Slots go on anything!
I put one in mine when I did the front suspension. Worked out well for pushing the truck into the garage.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 02-15-2014, 11:01 PM   #10
v30crewcab
v30crewcab's Avatar
they are like $10 at pullapart yards around here. I run them on everything. way better than the stock junk. rag joint will never be as tight as these.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 02-15-2014, 11:11 PM   #11
franken
The rag joint rebuild kits have been condemned as unsafe by a supposed former GM engineer due to the bolts tightening on rubber. Sorry, for the nonreference.
A new rag joint is around $90 if I recall after reading the above, possibly nonsense.
Do a web search and decide which direction to go...
Actually, I think the issue is our trucks aren't (typically) rack and pinion like newer, or the vehicles some drive daily, so the feel is different. Also, the feedback and effort of newer PS is more better than that of the old one finger PS.
Old 02-16-2014, 04:56 AM   #12
Billy81
Billy81's Avatar
Have you priced a NOS GM rag joint lately? Or one from Borgeson, Flaming River or IDIDIT. Sure Dorman makes rag joints for around $50-$60 but the quality is not that great. The only one that Dorman sells that would fit my truck caused my steering wheel to be upside down. I ended up having to buy this one from Jegs and at the time it was $79.99 http://www.jegs.com/i/JEGS+Performan...07050/10002/-1
Old 02-16-2014, 06:52 PM   #13
Skunksmash
Skunksmash's Avatar
Hmm... very interesting thread thank you for creating it.
But I'm struggling to understand the point of the rag joint. To look at that jeep steering shaft, it makes you wonder why it even exists. What could that rubber actually be doing? I'm... I don't get it. Why would you need this big mass of rag joint when you can just go straight to the box, and have nothing that will go bad?
I am tempted to do the same repair you did though. Only thing is, I really don't have any way of knowing if mine is even bad. I do have excess steering play, but that doesn't mean its for sure the rag joint. To clarify, you did say that the entire job only took you 30 minutes, right?
Old 02-16-2014, 07:25 PM   #14
Tx Firefighter
I'm sure Keith Seymore would know more specifics, but it's generally held that the rag joint absorbs some of the shock through the steering system to the wheel.
I believe strongly in GM engineering and retained the rag joint out of respect to that. I feel that GM trucks are the nicest driving trucks ever made. I do have experience with "solid" , non dampened, steering shafts like the Jeep one from some past street rods with Mustang II suspensions so I know it works well also.
Old 02-17-2014, 04:09 PM   #15
Skunksmash
Skunksmash's Avatar
I would agree about the nicest driving. Not sure what the comparison is between newer stuff but imo they have a tendency to ride a lot better and not be quite so stiff. Dodge is the worst! My neighbor bought a brand new one a year ago and I rode in it. I would have taken it back, it rode so rough. Or never bought it. The more I learn about dodge the more I know why they're the cheap stuff.
Old 02-19-2014, 07:09 PM   #16
Skunksmash
Skunksmash's Avatar
Used your guide and replaced the rag joint. Took me about an hour though cause I've never done it before.
Mine wasn't as bad as yours, but it did have a couple cracks that would have likely turned into something worse given some time. My holes weren't quite as waller'd out as yours were.
And I saw you live in springtown. I'm not too awful far from you, I'm in Cleburne. Course I might have mentioned that before... can't remember...
Old 02-19-2014, 08:04 PM   #17
Tx Firefighter
Thank you for telling me that. I'm very glad that someone got benefit from the article. Money saved is money that can be spent on more truck parts. Or hookers, or whatever.
Old 02-19-2014, 11:51 PM   #18
86Eric
Does anyone know what model Jeep and year period that he swapped it in with? I would watch the youtube video but it is not accessible on the computers here. I too am interested in the swap since my K10 will be my daily driver so the more comfort I can add, the better.
86Eric is offline   Reply With Quote
Old 02-20-2014, 12:22 AM   #19
1774btcrew
1774btcrew's Avatar
The ones I have pulled have always been from the 1984-1996 Jeep Cherokees. Hope this helps.
Old 02-20-2014, 01:39 AM   #20
Irish1941
Irish1941's Avatar
What he said.
NOT the Grand Cherokees. The square plain ones 2dr or 4dr.
Here's one I put in my truck. Notice the location of the lower pinch bolt.
That's dead straight aligned. Top one is 45 opposite of the bottom, on the top of the column with steering wheel straight. This only works on the later trucks. '81 or '82 I think was the change.
Irish1941 is offline   Reply With Quote
Old 02-20-2014, 02:28 PM   #21
oilmanpat
I have been building Street Rods for 25 years and was always taught that you kept the u joints inline or phased to avoid problems. The youtube video shows the joints turrn45 degrees from one another. ???????
oilmanpat is offline   Reply With Quote
Old 02-20-2014, 02:59 PM   #22
Irish1941
Irish1941's Avatar
Phasing u-joints is to cancel out vibration caused by u-joint harmonics.
Your steering shaft won't spin enough times or fast enough with them out of line to cause a problem.
Old 02-22-2014, 01:07 AM   #23
Skunksmash
Skunksmash's Avatar
Yeah I went ahead and replaced the rag joint cause of what he said about them engineering it to ride nice. In the end its just a trade off. Which do you want, more comfort or less maintenance. I like driving the truck and I find that the less comfortable it is, and the less luxuries it has, the more excuses I find to just drive my newer stuff instead. Also I chose to go with more comfort since it seemingly takes those rag joints about 20 years to die. Maybe less if you put a ton of miles on your truck.
Old 02-22-2014, 12:27 PM   #24
C10wip
C10wip's Avatar
I am guessing the effect is different ( better and more noticeable ) if you have manual steering; I think TX Firefighter's writeup ( which is very good and complete btw ) appears to show PS. On my manual unit the Jeep shaft seemed to improve it well beyond just removing the slop.
1980 C10 Custom Deluxe, 250 L6, 3 in the tree.
C10wip is offline   Reply With Quote
Old 02-22-2014, 12:33 PM   #25
1774btcrew
1774btcrew's Avatar
The upper u joint on these does have some sort of rubber dampener where it goes over the shaft. So I am sure this absorbs some of the vibrations. I know this as I considered just shortening this shaft instead of collapsing it some.
