Old 02-16-2014, 02:15 AM   #1
k7cdl
tire and wheel change over questions
right now i have 235/75/15 right now. i would like to change over to 245/75/16. would i have any problems with this change over? i'm taking off the running boards to give me a little more room.
k7cdl is offline   Reply With Quote
Old 02-16-2014, 08:37 AM   #2
nekkidhillbilly
Re: tire and wheel change over questions
i wouldnt think so. prob knock the speedo off but im sure your aware of that.
nekkidhillbilly is offline   Reply With Quote
Old 02-16-2014, 10:59 AM   #3
cadillac_al
You must have some free tires. You are going to lose your hubcaps. If you are buying tires there is always a30x9.50 or 31 or 32 x 10.50's to put more meat on the rims. If you have some cheap 16's with rims they should fit easy enough.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-16-2014, 04:40 PM   #4
k7cdl
yes that's the main thing i will hate is losing the hub caps but i like the load rating of 245/75/16
Old 02-17-2014, 08:52 AM   #5
cadillac_al
Oh, so you do some heavy towing? I have always wanted to have some 16" 5 lug steelies made for my half tons so I could run 235/85r16 tires and still keep my hubcaps. I have never found any already made though. I have seen 235/75r15 tires abused beyond belief when I worked in a grain warehouse. We used to load a ton of grain on 1/2 ton trucks and never heard of a blown tire but it is definitely not safe and the distances were short.
If you haul or tow heavy loads then you probably do need some 16's. I think you will have to go with an aftermarket wheel. I did buy some 5 lug 16" D spoke NASCAR style wheels for my truck but ended up selling them in the boxes before I got to try them. Those are usually less than $100/wheel. Actually Summit sells aluminum wheels for about $100/wheel.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 02-17-2014, 11:39 AM   #6
GRADYS Performance
GRADYS Performance's Avatar
The 245/75-16 tire will fit with no problem.
GRADYS Performance is offline   Reply With Quote
Old 02-17-2014, 03:41 PM   #7
k7cdl
its not so much i plan on doing heavy hauling but better to go over kill on load rating then go under rating. i'm sure that 454 puts a lot of weight on tires alone. plus in 2015 i'm going to look at doing a 5k mile trip and it would be nice to have a good set of 10 ply tires when hauling an ATV and a travel trailer for that long mile. I guess I just drove truck for 2 1/2 years no longer drive semi but learned in that 2 1/2 years better to go over kill on tires and not need the over kill then to need the better tires and be stuck in the middle of no where
