CAN'T FIX NOTHIN
Where can I find a pair of 15x8 6 lug steelies ?
Id like to put two 15x8 6 lug steel wheels on the back of my 67 I want to run the stock hubcaps , I looked on summit and wheel vintiques makes them but I dont think they have the bumps for.the hubcaps so I will have to find a pair of original used ones anybody have any for sale let me know I posted a wanted ad in the classified parts board I figure somebody will post on this section and may know where I can find a pair thank's
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Moderator
![]() Join Date: May 2007
Re: Where can I find a pair of 15x8 6 lug steelies ?
Dog dish caps work with wheel Vintiques steelies, a lot of people run them.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Not on the 6 lug version. Only the 5 lug has the knubs for stock dog dish caps.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
CAN'T FIX NOTHIN
The 6 lug ones they make they have a baby moon looking hubcap they sell for them the 67 c10 dog dish caps snap on the outside of the hub portion of the wheel on summit racing website they have a pic and wheels dont look to have the 3 BUMPS that the hubcaps snap on ? But it may be a bad pic ? Anybody out there got a set from them ?????
CAN'T FIX NOTHIN
Thats what I thought ,
CAN'T FIX NOTHIN
If the diameter of the center portion of the wheel vintique wheels is the same size I could weld on three bumps to make the hubcaps snap on ???
I called them up and asked, none of the 6 lugs have the bumps. They feel they won't sell enough of them in a 6 lug to make them. I guess everybody buys smoothies and puts on baby moons on the older 6 lugs.
I spent the last year trying to find a set of 6 lug steelies. Only ones I came across were from a vendor on here, and he had them newly powdercoated white and wanted a heavy price for them. I wanted them black, and I just couldn't spend that much to turn around and re-do them. I gave up a few weeks ago and bought some rallyes.
CAN'T FIX NOTHIN
I may check and see if the wheel vintiques ones are the correct size for.the hubcaps it will be easy to install the 3 bump snaps if they are the correct diameter ,
67-72 parts collector,…
![]() Join Date: Nov 2002
The Wheel Vintiques 6-lug wheels is a smoothie wheel.
(solid wheel) The correct wheel you want is their Series 62 wheel,... which they don't sell in 6-lug. 5-lug only. These wheels have the nubs for the dog dish hub caps and the 4 small windows in the wheels to match your front wheels. You need to look at 73-87 4x4 CUCV 15x8 wheels. A guy just sold 5 here on the board last week. http://67-72chevytrucks.com/vboard/s...d.php?t=616055
The wheel Vintiques 12 Series wheel has no windows and the ring is too big for your dog dish hubcap since it takes a small internal clip centercap.
http://www.summitracing.com/parts/wv...0604/overview/
CAN'T FIX NOTHIN
That smoothie wheel will work with some minor modification I couls make a set of bumps on that wheel to snap the hubcap onto , but yes the factory gm 15 x 8 ones like you pictured is the ones I want ,
I have a radical idea!
PM uncle or Southern Parts. They usually have some of them. I recently picked up some for my '68. You can get them in 5 or 6 lug, but the CUCV ones lolife mentioned are 6 lugs. They come on these:
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
BTW, the ones with 3 bumps sometimes don't have the 4 small slots (or windows) like your front ones do. The are solid. The ones with 4 bumps seem to have always have the slots. The CUCV have 4 bumps instead of 3. There are least 3 different styles of these wheels that I've seen.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-15-2014 at 03:50 PM. |
To clarify, some of the 3 bump wheels have the slots, and some don't. All of the 4 bump wheels I've seen (5 and 6 lug) have had the slots. I have one 3 bump wheel with no slots that has mounting holes for a center cap also. The CUCV 4 bump wheels do not have any center cap mounting holes.
#15 |
CAN'T FIX NOTHIN
With a deeper dished wheel and mine are black I dont mind if they have those little window slots or not ,,,,
#16 |
Your factory ones should have the little slots anyway. I talked with uncle a few minutes ago, and he said he didn't have any at the moment. You can still check with Woody (Southern Parts). He had some at one time.
#17 |
Stockton wheel should be able to make you a set
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#18 |
x2 ^^
But I bet someone will come up with a GM set
#19 |
CAN'T FIX NOTHIN
Lots of good discussion here im gonna hold out for an original gm set but if not I may get the wheel vintiques or have a set made but I bet someone will want my money LOL
#20 | |
http://www.ebay.com/itm/15x10-Chrome...c0aa9f&vxp=mtr
#21 | |
Those take the stock caps
#22 |
CAN'T FIX NOTHIN
Just from looking at the pic the wheels vintiques wheel pictured above looks.like the stock cap would fit but it dont have the bumps for the cap to snap if I knew that was the case I would order two of them ,,,, has anybody actually tried to see if a stock cap will fit up on the center of one of those ?
#23 | |
