02-16-2014, 06:56 PM | #1 |
Solenoid Wiring Hook-up
I took out my starter to change my solenoid (intermittent problems). I noticed there were 3 wiring locations with 2 attached (battery and something else). There was a 3rd wire hanging down with no connecter end (and not connected). Any thoughts about what this is? Does it need to be attached?
02-16-2014, 07:00 PM | #2 | |
The Older Generation
Re: Solenoid Wiring Hook-up
If you have an HEI distributor and the wire is yellow you don't need it.... LockDoc
02-16-2014, 07:07 PM | #3 |
Not HEI. Original. Apparently the other is the switch. Not sure as to the other wire.
02-16-2014, 07:38 PM | #4 | |
LockDoc
02-16-2014, 10:56 PM | #5 |
It's odd because I don't think it was connected. It definitely doesn't have a connector and is a bit shorter. Will is start with just the switch and power?
02-16-2014, 11:07 PM | #6 | |
LockDoc
02-17-2014, 10:34 AM | #7 |
Like doc said. The points wire is closet to the frame rail when the starter is installed. The ign switch is closest to the block.
02-17-2014, 01:02 PM | #8 |
It must be the points wire. It was starting fine (except for the solenoid not kicking out fully.
