Old 12-26-2003, 10:59 AM   #1
kickboxr3
Question detent cable for a 700r tranny question
I am in the process of swapping my th350 in my '71 for a
700r transmission. I looked in the LMC catalog and did not
see any such cable for the 700, just only the 350 and 400.
Anybody out there have any ideas of where to find one?
kickboxr3 is offline   Reply With Quote
Old 12-26-2003, 11:09 AM   #2
ckhd
ckhd's Avatar
www.700r4.com
It's where I got mine.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 12-26-2003, 11:14 AM   #3
kickboxr3
Talking
Thank you very much i am checking it out now.
Old 12-27-2003, 12:42 AM   #4
Don Smith
You can get them from GM. Cost in twenty dollar range.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 12-27-2003, 02:14 AM   #5
Injected68LS1
Injected68LS1's Avatar
Check out the EZ TV cable from the 7004r.com. I have it on mine. I actually have one from before I swapped engines(I have the LS1 TV cable now). It's for a holley carb. It has the base, linkage, and the cable. I'll give you a good deal on it. It worked perfect. You can set up how hard or soft you want the tranny to shift. That also makes it shift later or earlier. Let me know.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 12-27-2003, 09:38 AM   #6
kickboxr3
Talking
Hey injected,
I have a sbc350 w/ holley 670 avenger series 4brl carb, will it work on this set up for the 700r? If so how much?
Old 12-27-2003, 03:11 PM   #7
Injected68LS1
I'm not real sure. I know it works on a 4150 and 4160 series. I bet it's the same. I guess I'll have to call bowtie overdrives.
Old 12-27-2003, 11:13 PM   #8
Chevyguy111786
Hey injected, you got details of where you got it? If you havent sold yours i might be interested.
Chevyguy111786 is offline   Reply With Quote
Old 12-28-2003, 03:17 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just be carefull on that adjusting shift points and shift firmness...if you don't have instant line pressure increase as soon as you open the primaries, the tranny will fall apart in short order.
Old 12-28-2003, 05:32 AM   #10
Injected68LS1
Your right about the line pressure. But the EZ linkage makes it so you always have line pressure. It just adjusts how quickly the TV cable is pulled. At wide-open-throttle it pulls the cable the same amount and hence applies the same amount of pressure the the transmission clutches.
Old 12-28-2003, 03:38 PM   #11
Longhorn Man
Cool. I have never heard of the EZ linkage you are talking about, I wanted to make sure line pressure was mentioned since it is the main thing that will kill an overdrive tranny.
Old 12-28-2003, 05:53 PM   #12
gunnersm8
hey ive got some questions about the 700r4 swap on a carb engine- hows it work? do you like it? you need a switch? how does it work?
gunnersm8 is offline   Reply With Quote
Old 12-28-2003, 05:59 PM   #13
Slammed67
Progress = 0%
Slammed67's Avatar
I also have the Bowtie Overdrives EX linkage and it works great. Well worth the money in my opinion.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 12-29-2003, 09:31 PM   #14
nate68
i have Lokar's setup. all of their products are high quality
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 12-29-2003, 09:49 PM   #15
onelow69
onelow69's Avatar
I have the EZ 700r4 Botie overdrive set-up and it works killer. You can set up your shifts soft or frim depending on what you want. It a bit pricey but well worth it. Make sure that you get the line presure kit with it as well. That helps you get the TV presure right. I spent around 130.00 for the hole setup. Also make sure you use a 4th gear lock up kit. It real simple to hook up to.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect.
onelow69 is offline   Reply With Quote
Old 12-30-2003, 12:34 AM   #16
Chevyguy111786
What do all these parts do? I just bought a 700r4 that i'm gonna have rebuilt with a heavy duty rebuild kit, shift kit of some sort, and a new torque converter...all for 600 bucks. bought the tranny for 50. I'm wondering which parts i will need to go from my t350 to the 700. But more than anything just interested in what each does.
