Old 02-17-2014, 11:02 PM   #1
bigchopperguy
auxilary tank bolts
Hi all, I need to replace the thru bolts that mount the auxiliary tanks through the bed. They are 7/16 x 13 inch carriage bolts with a special nut on the bottom. Anyone familiar with this setup? any advice for replacement bolts much appreciated. john
bigchopperguy is offline   Reply With Quote
Old 02-18-2014, 08:56 AM   #2
Daddy Brim
Daddy Brim's Avatar
Re: auxilary tank bolts
I would think you should be able to get them at your local hardware store.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 02-18-2014, 11:07 AM   #3
Prematuregrey
Prematuregrey's Avatar
Good luck sourcing the original types. Maybe try taking the bottom "nut" to a machine shop and have then turn a few out. The carriage bolts might be easier to find but will take some sourcing. Fastenal will special order them but they are proud of them for the size. When I refurbed my tanks, I broke one of the long carriage bolts and just used some all thread and Nyloc nut with a body washer for the top. It sucks having a big nut sticking up in the bed but it works till I can find another for a reasonable price. I was able to save the lower nut with a tap though. I spent a week or so looking for replacements but no luck. If you do find some, let me know and I'll grab a set as well. Check out some RV and 18 wheeler shops, those tanks are not factory and originally came from a RV accessory manufacture.
Owner: Times Are Tough Toys
92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it.
89 Mercedes 560 SEL, Merdle. Wrecked
71 Chevy K20, Clifford, BB and 1 Tons
Prematuregrey is offline   Reply With Quote
Old 02-18-2014, 02:02 PM   #4
mrein3
mrein3's Avatar
I made my own. Two carriage bolts welded to all thread. I used regular nuts on the bottom after a fender washer and lock washer. They have been working good for over 11 years.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-22-2014, 02:55 AM   #5
bigchopperguy
Thanks for the replies. I was able to save the nuts so I will be making my own bolts from 7/16 u-bolt stock from the spring shop. I made plates for the top out of 1/4 x 1-1/2 flat bar. thanks again
