Old 02-16-2014, 04:40 PM   #1
Stepper86
Stepper86's Avatar
Headers for LS swap?
I searched the forum and net to find out what headers people are using for their LS swaps. Maybe itīs just my lack of skill with search engines, but I have not been able to find that many options.
Seems like Thorley and Schoenfeld are popular,but are there any others worth looking at?
I would prefere to go with longheaders.
All so, what type of engine brackets have you guys used with longtubes? Didi you have to move the engine forward to get the headers to clear?
Any advice apriciated!
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 02-16-2014, 05:31 PM   #2
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Re: Headers for LS swap?
Dynatech 70-81 Camaro I believe with the right mounts
ksbrktracer is offline   Reply With Quote
Old 02-16-2014, 11:00 PM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
used the 99+ pace setters. dented both sides and trimmed the frame rail on the driver side.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-16-2014, 11:27 PM   #4
Blackpony
Blackpony's Avatar
See this thread
http://www.67-72chevytrucks.com/vboa...d.php?t=609953
Blackpony is offline   Reply With Quote
Old 02-16-2014, 11:42 PM   #5
68c10airstream
68c10airstream's Avatar
Hi stepper86, before i did headers i considered mount location for stock a/c and exhaust position and i chose the 2001 organ donor mounts. They obviously work with factory low mount a/c and because the mounts sit low they are never in the way of any exhaust style. I believe firebird/camaro LS1 (98-02) and trailblazer-envoy-rainer with 5.3/6.0 are a mount that looks like a hockey puck horizontally positioned down low. These mounts just require a little fab work with 1/4" plate to the crossmember and then you will have nothing in the way. Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 02-17-2014, 02:59 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
There is some fudge, depending on what exact setup you are running. The TBSS cast manifolds are the jack-of-all fits on swaps, since they have an ultra low profile and clearance. The same goes for the hooker cast-style manifolds, which just like the TBSS mani's has all its runners into one main pipe, instead of the individual tubes, which add to the width and drop of the exhaust.
For longtubes, the DT's are still extremely popular since they are offered in the larger diameter for those needing the extra ponies.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-17-2014, 05:57 AM   #7
smoky02
Location: Sunny, Florida, some might call it South Alabama
I used to TBSS longtube pacesetters, but I did have to dent the drivers side header a little.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 02-17-2014, 06:44 AM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: Headers for LS swap?
Here are the long tubes that I used. They fit with hardly any frame work on passenger side. There not cheap though. I used regular motor mounts with neopreme with a adapter plate.
http://67-72chevytrucks.com/vboard/s...d.php?t=616072
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-17-2014, 11:49 AM   #9
First c10
First c10's Avatar
This is my Driver side header. They are headers from eBay they were cheap so I thought I would try them fit pretty good i didn't have to trim anything. But they are short not long type. I will post picture of the passenger side also. I a, using early classics mounts and trans crossmember.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 02-17-2014, 11:50 AM   #10
First c10
First c10's Avatar
Passenger side
GO GO!!!
Old 02-17-2014, 05:05 PM   #11
Stepper86
Stepper86's Avatar
holy $$..... Yea they are a bit on the expencive side, I will look in to if they are available in Europe. If not then the freight would kill me.
How much is a "little" ? Could the frame be trimmed a bit instead?
Originally Posted by First c10 View Post
Passenger side
Looks ok, do you have a link to them? Itīs not exactly what I was looking for but might be worth looking in to.
The fleet:
Old 02-17-2014, 05:09 PM   #12
Stepper86
Stepper86's Avatar
I did not think of TBSS cast manifolds, will have a look at it.
Thanks for the tip.
The fleet:
Old 02-17-2014, 05:14 PM   #13
Stepper86
Stepper86's Avatar
Originally Posted by Blackpony View Post
Had a look at your link, these fit really nice. Looks like there are plenty of space.
Canīt see it on the picture, do they come with o2 sensor fittings?
The fleet:
Old 02-17-2014, 05:44 PM   #14
mooseknuckles
mooseknuckles's Avatar
If you want real "long tube" headers that fit great....http://www.dynatechheaders.com/m_camaro_70_81.html
mooseknuckles is offline   Reply With Quote
Old 02-17-2014, 05:52 PM   #15
mooseknuckles
Old 02-17-2014, 08:43 PM   #16
jamesjones
Freakin Awesome!
jamesjones's Avatar
Do you have these? If so, could you take some measurements for me?
I refuse to spend $600+ on a set of LT headers unless I'm absolutely certain they'll fit.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 02-17-2014, 09:16 PM   #17
mooseknuckles
I can, but it won't be till the weekend...
Old 02-17-2014, 09:25 PM   #18
mooseknuckles
pics in my build thread...page 39.
Old 02-17-2014, 09:47 PM   #19
jamesjones
Freakin Awesome!
jamesjones's Avatar
Cool, thanks. No rush, whenever you happen to have the hood open next if you could just measure from the head to the outside of the pipe at the flange.
Old 02-17-2014, 10:09 PM   #20
Andy4639
Old member
Andy4639's Avatar
Talking Re: Headers for LS swap?
The drivers side of mine was a direct placement no mods to anything. Pasenger side they barely cut the top flange of the frame rail and then heated it up bent it down and rewelded it. very nice job and you must really know your frame rails to know where they did it.
Old 02-18-2014, 12:47 AM   #21
smoky02
I had to dent one of the tubes in about an 1/8 of an inch, it was touching the frame. But that is also using ECE mounts all the way back.
Old 02-18-2014, 02:48 AM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
For 600+ my money still goes to DT. Just because of the large tube, quality, guaranteed fit, and the fact that he was the first to do them for us.
Old 02-18-2014, 02:50 AM   #23
jamesjones
Freakin Awesome!
jamesjones's Avatar
It's not a guaranteed fit. I don't think they'll work in my setup.
Old 02-18-2014, 06:42 AM   #24
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Unless you are set on headers, TBSS manifolds are a no-brainer. They fit great and use the flanges from the 5.3 truck manifolds. Here is a link to GM parts direct
http://www.gmpartsdirect.com/catalog/frameset.cfm
in the search box, put 2007 Trailblazer SS
Total for both manifolds w/o shipping is around $100 bucks! Whadda deal!
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 02-18-2014, 09:08 AM   #25
Andy4639
Old member
Andy4639's Avatar
I wouldn't buy $600.00 headers and then dent them in to fit. You just took the advantage away of the header in my opinion. I know it's your truck but I would have rather tweeked the frame than the headers.
