Old 02-18-2014, 10:22 PM   #1
chebyshortbox65
chebyshortbox65's Avatar
Legal ls swap
Just got my first ls swap legal in good ole so Cali. Passed flying colors on my first attempt how many other guys had a engine swap approved by the smog police?http://i1290.photobucket.com/albums/...psioc2xrsi.jpg
chebyshortbox65 is offline   Reply With Quote
Old 02-18-2014, 10:33 PM   #2
Ziegelsteinfaust
Re: Legal ls swap
I did years ago. I put a 350 sbc in place of a I6 in a Nova, and it wasn't all that bad. Just more annoying then anything setting appointments, and then waiting.
Ziegelsteinfaust is offline   Reply With Quote
Old 02-18-2014, 11:20 PM   #3
natedogg
Re: Legal ls swap
My wife is from so cal, but lives here in nort west Tn now. She has told me about the smog laws in cali. It is no problem here in my county. We don't have to do smog test. We just go to court house and get tags for your vehicle. My 85 Silverado has straight dual exhaust with no cats. You can swap any engine in any kind of vehicle and not have to worry about a smog test. Put a carbed V8 in a 2000 S-10 and no problem getting it registered.
natedogg is offline   Reply With Quote
Old 02-19-2014, 08:45 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Legal ls swap
SC doesn't even require a state inspection anymore. They were so dishonst about them the state stopped it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-19-2014, 11:58 AM   #5
littlevictories
Re: Legal ls swap
just the big metro areas that get lots of smog here get the inspection
anywhere in the valley basically.
kudos man. I lived in the the bay area for some time and I know passing California DEQ inspection deserves a pat on the back.
they can be real nazis about that ****.
littlevictories is offline   Reply With Quote
Old 02-19-2014, 12:18 PM   #6
truckdude239
truckdude239's Avatar
Re: Legal ls swap
here in nc (now remenber i am a nc state inspector) Anything 35 years or older no\\are exempt from inspections. but anything 34 years or new has to have the original size engine, and emission componates still installed and can not have been tampered with.
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-19-2014, 01:36 PM   #7
osaltyone
osaltyone's Avatar
Re: Legal ls swap
Congrats! If I ever go legal I'll hit you up. I'd imaging it was a pain getting evap and purge hooked up and everything running.
osaltyone is offline   Reply With Quote
Old 02-19-2014, 01:40 PM   #8
jamesjones
Freakin Awesome!
jamesjones's Avatar
Re: Legal ls swap
So glad my Blazer is a '72 and I don't have to bother with smog.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 02-19-2014, 04:30 PM   #9
solidaxel
solidaxel's Avatar
Re: Legal ls swap
Even if it is a CLEANER burning engine with a tail pipe test?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-19-2014, 07:08 PM   #10
truckdude239
Re: Legal ls swap
We dont do tailpipe testing its all done as obd2 after 1996. Everything else is saftey but everything still haas to be there
David fuller
2000 Tahoe 5.3l 378
Old 02-20-2014, 01:15 AM   #11
chebyshortbox65
Re: Legal ls swap
10-4 salty how is the harness working? It was pretty easy to make it all work more research then anything the cats were a pain i ended up cutting the stock y pipe and fabbing up new down pipes into a pipe then I did my own tune.
Old 02-20-2014, 01:17 AM   #12
chebyshortbox65
Re: Legal ls swap
Thanks for the words guys if anyone needs some advice I'm always willing to help I gotta get the 87 caprice with a ls3 inspected next for the guy I'm building it for
Old 03-01-2014, 06:26 PM   #13
mattcrp1
mattcrp1's Avatar
Re: Legal ls swap
Great job! I have a 76 I am doing right now. My only question is in regards to the EVAP system. How did you do this? If you have a build thread or pictures that would be great. My truck is registered in a non-smog area of California, I am in non op at the moment, I am not sure if I will need an initial smog for the tags or not so I may need to be totally compliant. Any input would be great. What fuel tank did you use?
Thanks,
Matt
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-02-2014, 12:17 AM   #14
71K20chevy
71K20chevy's Avatar
Re: Legal ls swap
No smog testing here in IN either. Even then, my truck is old enough there's nothing they can do about it...
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-03-2014, 09:19 PM   #15
chebyshortbox65
Re: Legal ls swap
We'll you can go two ways on the evap you can have your tuner turn off all the related codes for the evap and the I/M moniter will set to ready or you can run a resistor in to fool the ecm into thinking it has half a tank of fuel only problem with that route is the test will fail eventually because the ecm does not see the fuel level change and thinks the float is stuck in range the nice thing is the evap still works just fine when the codes are disabled it just dosent run the test I have 3000 miles so far with no problems @mattcrp1
Old 03-04-2014, 11:40 AM   #16
mattcrp1
mattcrp1's Avatar
Re: Legal ls swap
Thanks for the response. I think I will have the evap codes turned off when I get tuned. Are you running the original evap canister and just plumbing it into the evap solenoid on the engine? Did you hook up a fuel tank pressure sensor? I am not totally familiar with GM stuff. I have an 87 fuel injection tank and I am going to run an in-tank pump so I think if I hook up a newer canister and plumb it all together it should work. Thanks for input.
Matt
IG mattcrp1
