02-19-2014, 12:16 AM | #1326 |
A320 Pilot/USAF Retired
Re: 68 S/C update.....
Probably the best looking '68 on the planet!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
02-25-2014, 12:37 AM | #1327 | ||
1 Do you have any "final" pictures of your shift linkage and what did you have to modify 2 Do you have any pictures of the back side of the pedal mod/were there any issues on the other side of the firewall or did you just use the original pedal bolts to hold it in (i observed a ~1/2" bolt at the top) 3 any final horsepower numbers I am starting a 6.0 ly6/6l90 from a 2009 3/4 ton and these are a few loose ends I am trying to iron out. Your knowledge would be much appreciated! This is one sweet truck. Mine will not be this nice but I am shooting for something in the same ballpark.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
02-26-2014, 07:04 PM | #1328 |
Truck is turning out amazing
02-26-2014, 07:50 PM | #1329 | ||
I'm glad you like it! Quote:
2. I didn't have to modify the pedal any. Its bolted to a flat bracket that bolts to the firewall using the 3 original nutserts that the original pedal bolted to. 3. It should be around 600+ RWHP Thanks!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-28-2014, 09:16 PM | #1330 |
very very cool brother rock on!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
03-02-2014, 10:15 AM | #1331 |
Would you mind sharing some details on your oil and transmission cooler setups? I would appreciate the info.
From some of the pics it looks like you are using a Derale heat sink cooler mounted under the core support for oil. Didn't see the transmission cooler setup. Thanks - Chad
1967 Chevy SWB 1972 Chevy SWB 1972 Chevy SWB K20 4x4 1991 Ford F-150 2013 Dodge Ram 1500 4x4 |
03-02-2014, 05:39 PM | #1332 | |
Thanks, glad you like it!
03-02-2014, 09:18 PM | #1333 | |
http://derale.com/products/coolers/a...unt-kit-detail For the oil cooler I'm guessing you are talking about the stock cooler that came on the Camaro oil pan? I'm with you, I don't see a way to make it work with the slider mounts. I was thinking about trying something different with that, using a remote mounted cooler and an adapter. Not sure if you've looked at the ones from Improved Racing, but they have a thermostat built into them and AN fittings so you can mount a cooler wherever. They do have a version without a thermostat, too. Seems a little expensive and I'm not sure if its necessary to have an oil cooler anyway. http://www.improvedracing.com/cooler...28e4c74df943c5 Thoughts?
03-02-2014, 09:30 PM | #1334 |
If you're scared, just say you're scared......
03-06-2014, 01:33 PM | #1335 |
Getting ready to drop some coin on a new stall converter. Leaning towards a multi-disc 3000 stall.....
03-16-2014, 12:12 AM | #1336 |
Hart Rod.... It took me THREE (3) days to read your 54 page thread... All I can say is... Wow... Your project is insane and you have given me several ideas for my new LQ9 engine swap. If you don't mind, I will begin picking your brain tomorrow.
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
03-20-2014, 04:47 PM | #1337 | |
The new Circle D converter showed up today!!!
03-22-2014, 11:54 PM | #1338 | |
Rollin' Old Skool
BTW, the truck looks awesome! It has changed a good bit since I last saw it. Keep up the nice work.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
03-24-2014, 11:14 AM | #1339 | |
03-24-2014, 12:18 PM | #1340 |
Rollin' Old Skool
I'm not sure what he has now. When we moved, he had a newer body style S-10 reg. cab that was pearl white & mildly customized. At the time, he was also working on a 73-87 Chevy pickup. I wanna say it was brown. Last time I spoke with him, he mentioned he gave the S-10 to his son.
Here's a better pic of him when we were at Cruisin' the Coast '09: http://www.flickr.com/photos/98543199@N05/12213724574/
03-24-2014, 05:23 PM | #1341 |
subscribed.
69 c10, mild 350, TH400, LWB......Starting build 3/14 |
03-24-2014, 09:03 PM | #1342 |
03-24-2014, 09:14 PM | #1343 |
265mm Pro III 6L80E Torque Converter, 2800 Multi-disc:
http://www.circledspecialties.com/p-...converter.aspx
03-24-2014, 09:28 PM | #1344 | |
A day late and $1 short...
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
03-24-2014, 10:06 PM | #1345 |
I'm waiting on my good friend from Niceville to come over......
03-24-2014, 10:25 PM | #1346 |
I'm trying to go the way of the blister... show up AFTER the work is done!
03-25-2014, 09:26 AM | #1347 | |
03-26-2014, 08:42 AM | #1348 | |
Vintage Evil
Just curious... why did you decide on this brand over others? Previous experience?
03-26-2014, 10:00 AM | #1349 |
Several friends recommended it.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-26-2014 at 12:04 PM. |
03-26-2014, 10:13 AM | #1350 |
Yep, Circle D is the best choice for LSx converters. Great prices, great products, and great customer service!
