Old 02-20-2014, 12:32 AM   #1
purplehavoc
3/4 ton front end suggestions
Hey guys,
So I have finally gathered up most of my parts to start building my 56, and I am wondering what you guys might have for suggestions for a front end in my truck. I am thinking about going with the 8 bolt reared I already have, and would like to keep the truck 2wd if I can. The frame is a 57 3/4 ton long box that I will be shortening down, as it is already a pretty stout frame.
I have a complete running and driving 04 Chevy 1 ton express van that I bought for the powertrain swap into my 56.
Any thoughts on a 8 bolt front end I could swap into this truck would be greatly appreciated.
09 GMC 2500HD 6.6L
07 F-250 Super Duty V10
03 Chevy Tahoe
82 K5 blazer plow truck,currently under the knife
56 GMC stepside short,also in progress
purplehavoc is offline   Reply With Quote
Old 02-20-2014, 02:10 AM   #2
ghettoluxury
ghettoluxury's Avatar
Re: 3/4 ton front end suggestions
The easiest one to swap is going to be from a 73-87 Chevy. They are pretty cheap and relatively easy to find.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-20-2014, 09:19 AM   #3
purplehavoc
I have read of some guys narrowing the cross member of the 73-87 2wd trucks to install them in order to get tires tucked more, is that needed if the truck will not be slammed down?
09 GMC 2500HD 6.6L
03 Chevy Tahoe
Old 02-20-2014, 10:01 AM   #4
whitedog76
The rearend from the Express is a little too wide for your truck. The one I had was 70" WMS-WMS.
Keep your front axle on the 57 and do a disc brake swap like Nick is doing, with your van components.
http://67-72chevytrucks.com/vboard/s...d.php?t=586788
whitedog76 is offline   Reply With Quote
Old 02-21-2014, 08:46 PM   #5
mobileortho
mobileortho's Avatar
I used the 73-87 clip on my 50 but narrowed it so it doesn't look like Dumbo. You should be fine because the TF's are wider than the AD's.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 02-21-2014, 10:43 PM   #6
57chevyman
57chevyman's Avatar
My '57 truck has the front clip from a '68 Chevy truck.
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 02-22-2014, 08:28 PM   #7
purplehavoc
I do have a 1980 C20 parts truck that I could rob the clip out of, just have to wait for the 5 feet of snow to melt so I can get to it.
Anything drastic have to be done as far as steering linkages when narrowing the clip?
09 GMC 2500HD 6.6L
03 Chevy Tahoe
Old 02-23-2014, 09:34 PM   #8
jetnow1
The narrowed c-10 front ends are to tuck the tires and make the frame width match the
AD frame, the later trucks already have a wider frame than the AD pickup. Putting a c-10
or C-20 front end in a 56 would take a lot of frame changes- negating the bolt in reason to
use the c-10/20 front ends.
jetnow1 is offline   Reply With Quote
