Where to get inexpensive quality antenna assy?
My antenna on the 87 has always been a little junky. Finally getting around to fixing it. Had a couple different new radios and they had lousy reception. So Im going to try a new antenna, and cable. ACdelco wants a little more than I think its all worth. Bout $35 after shipping.
There should be some aftermarket company that makes a decent setup, but which one? Autozone and oriellys don't list one on their website and Rockauto seems to only sell Acdelco. Ebay is clogged with all manner of junk so I was hoping someone here just knew where to find what I'm looking for. |
Re: Where to get inexpensive quality antenna assy?
Bump
#3 | |
A few months ago I bought this antenna from Amazon: I've been very happy with it. It was a noticable improvement over what I had before, and the quality seems to be just fine. Not sure if there may not be something better out there, but I was pleased with the price and it is quite a bit less than the $35 you mentioned.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
STILL PLAYS WITH TRUX
87's Had the factory antenna inbeded in the windshield not mounted on the fender.
If that's what you have now I would just go digin' around the junk yard's just about anything from any other GM vehicle should work. Best of all you'll probably only pay 5 or 10 bux! Good luck. |
#5 | ||
And since my fender antenna seems to somehow perform so poorly, I figured I probably shouldn't risk getting one from the junkyard. Cause I might just be buying the same problem. I had heard from some car show that antennas can eventually go bad, and you just buy a new one to fix it. Not real sure exactly what the root cause is. Perhaps weakness and/or stress cracking internally, who knows. Something begins to impede the signal I guess. Quote:
I have an antenna like the one linked to above. It works well, but doesn't fit well. With how the tops of our fenders are, it slants it off to the side. I suggest you hit up a junk yard and get a factory one off a suburban. I plan on doing that this summer. Here is a picture of how mine hangs off to the side. And there is no way for an antenna to "wear out," it's just a piece if wire.
Few things in life will make you look stupider than putting a dollar sign after a number. |
I have to disagree there, I've replaced plenty of wore out wire.
Chips, cracks, oxidization, rubbing, etc etc Even wire that was subjected to no outside forces like old cable wire inside a building. Sometimes they have to replace old coaxial cable because its not good enough for the internet anymore, you get packet loss because the wire is simply too old. And its been the the wall the whole time. And they replace it with just more coaxial cable, just new. |
Cruzzzn' Vet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
