02-22-2014, 07:20 PM | #1 |
Ho52 axle seal or axle shaft flange gasket?
Hey guys I was driving my truck today and this happened. Not sure if I need to pull the hub off and replace the seal or is it just the axle shaft flange metal gasket? Any help is appreciated. Thanks.
02-22-2014, 09:06 PM | #2 |
Re: Ho52 axle seal or axle shaft flange gasket?
It looks like the axle gasket. I don't see any oil puddling up on the back of your rims.
02-22-2014, 10:52 PM | #3 |
Proprietor of Dale's Corner
Gasket...but remember to top off the diff oil
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
02-22-2014, 11:40 PM | #4 |
Thanks guys. Yea I looked and no oil dripping out the bottom of the brake drum.
02-23-2014, 11:42 PM | #5 |
This from the '69 Service Manual may help, too.
"To prevent lubricant from leaking through flange holes, apply a non-hardening sealer (such as Permatex Type A or equivalent) to bolt threads. Use care in the amount of sealer applied, as in too heavy an application, the sealer may be forced out as the bolt is installed and may destroy the sealing effect of the flange-to-hub gasket".
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
02-24-2014, 12:13 AM | #6 |
Thanks for the info. I did forget to do the thread sealer when I did the brake service. I'll be sure to pick some up along with the gasket.
02-24-2014, 12:36 AM | #7 |
Use the Grey silicone Permatex that's made for differentials, it resists gear lube.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-24-2014, 01:01 AM | #8 |
20' Daredevil (Ret)
^ Yes -- it's good stuff, far better than RTV silicone when gear oil is involved. Part no. 81182.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-24-2014, 03:32 AM | #9 |
^ That's the stuff!
02-27-2014, 01:44 PM | #10 |
^ Didn't know there was such a product. I'll try it next time.
