Old 02-20-2014, 11:40 PM   #1
cjlloyd81
cjlloyd81's Avatar
1986 GMC C3500 Rear Power Window Regulator
I'm at a brick wall here. I've located/ordered/have motors for all four windows, and window regulators for the front doors. Orielly's, AutoZone, NAPA, Classic Indusries, JC Whitney, LMC Truck... all are making me think I"m crazy because no one lists or can find regulators for the rear windows. The ones for the front in every system/catalog specifically state Front Driver, or Front Passenger.
Short of pulling them out (cause thats alot of fun) and comparing to the front's... Can anyone tell me if they are the same front/rear?
1986 GMC C3500 4 door long bed dually. wings on the front window, and inop sectional glass on the rear.
cjlloyd81 is offline   Reply With Quote
Old 02-21-2014, 12:51 AM   #2
mrolds88
Re: 1986 GMC C3500 Rear Power Window Regulator
Use Suburban as application. same thing. BTW. Interesting visor, any info on it??
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-21-2014, 12:54 AM   #3
cjlloyd81
cjlloyd81's Avatar
Oreilly's parts listing for a '86 GMC Suburban. Still only shows front windows...
Old 02-21-2014, 08:46 AM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
Maybe having the OE part #'s will help. Here is the listing for the back door window regulators for an 86 C3500 crew cab. Heck it shows the left side is still available from GM for $135.70 retail.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 02-21-2014, 10:52 AM   #5
mrolds88
Does the truck have power windows now and you want to replace or are you upgrading? If you are replacing, what is wrong with whats in there now?
93 K2500 xcab 6.5TD
Old 02-21-2014, 12:58 PM   #6
cjlloyd81
cjlloyd81's Avatar
Power windows are factory. I'll have them cross those part numbers but I got a feeling they're going to come back as the front regulators.
Old 02-21-2014, 04:57 PM   #7
RandyP
RandyP's Avatar
Fronts and rears are totally different parts.
Old 02-21-2014, 05:08 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
nice truck
you can use manual ones till you find them,crank comes threw the switch hole
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-21-2014, 06:38 PM   #9
rs72z
rs72z's Avatar
Unless the roller has gummed up and bent the regulator there's not a lot to go wrong with them. Most just need a good cleaning and greasing.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 02-21-2014, 11:12 PM   #10
cjlloyd81
cjlloyd81's Avatar
No, no idea on the visor, the rear cab fin, or the bed cover. Just that the bed cover is custom aftermarket, and from what I was told by the original owner the visor/fin came on it. It was a custom order by a Chevrolet dealership owner originally.
When I bought it none of the windows worked, or even tried to go down. So I got a new/reman motor and took the drivers front door apart. Changed the motor, put WD40 on every moving part of the regulator. I also manually moved the regulator, and used the motor prior to installing it back in the door. (could they make that any more fun? really...?) The window worked well for a month, tho it came to a stop at the 1/2 way mark till you touched it then it'd go the rest of the way. And now nothing, not even trying to move. I'm got a new regulator that'll be in tomorrow, and I'm going to warranty the motor as well.
I did spray wd40 down the side tracks of all 4 windows and since then the RR window will open and close tho its slow.
Thanks for all the attention and ideas guys I really appreciate it.
-Chris
Old 02-22-2014, 01:50 AM   #11
joe231
joe231's Avatar
Wd40 is not a good lubricant. I would either use grease or some spray lube like silicone or white lithium.
PB blaster makes a garage door spray lube that works great.
http://www.blastergroup.com.au/garag...lubricant.html
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-22-2014, 10:24 AM   #12
mrolds88
I'm with Joe. Also you might want to look into the relay mod that is on here. Also sounds like the problem is electrical. Check over your switches and wiring. Switches are easy to disassemble and clean.
93 K2500 xcab 6.5TD
Old 02-22-2014, 01:55 PM   #13
joe231
joe231's Avatar
I agree, in my experience the old corroded switches are usually the culprit. Disassemble, clean the contacts and apply a good dielectric lube on them. Don't forget to clean the connectors and pins on the back of the switch. A little dielectric there helps too. You might even need to bend the contacts in the connectors to make better connections also. Corrosion at any of the connections will drop the voltage that actually makes it to the motors. You can even replace brushes in the motors and clean the commutator while apart. It's not extremely difficult, just takes some patience. All these things need maintenance, but most never receive any attention.
CHEVY ONLY
Old 02-22-2014, 03:38 PM   #14
cjlloyd81
cjlloyd81's Avatar
I never thought of that... When I have my drivers door apart I'll play with the multimeter and check for resistance.
Thanks guys.
Old 02-22-2014, 09:20 PM   #15
cjlloyd81
cjlloyd81's Avatar
Well I totally didn't think of the switch as a possibility. So thank you all for suggesting that. I took the Drivers door panel off and jumped the connections on the plug itself and every window worked, passenger front was slow but they all worked. So I cleaned up the terminals on the switch plate, tightened the connections in the plug and still had the same problem.
I had an already scheduled meeting with someone to buy a Qjet and SBC manifold (just wanted the carb but for $40 couldn't pass up the included intake) and it so happened he was parting out an 80's suburban while I was there so I picked up every switch the suburban had (the 4 switch drivers door window switch, three single window switches, and two lock switches) for $20 extra.
Brought the new switches home and plugged the 4 switch window one in and jackpot. If anyone that helped with this is ever in southern Oregon let me know, I owe ya'll a beer. You saved me a lot of money from replacing all the motors and regulators. So thank you again.
-Chris
Old 02-22-2014, 09:26 PM   #16
joe231
joe231's Avatar
Awesome!!!
Glad it worked out for you!
Btw, what kind of bed cover do you have on your truck?
Any pictures?
CHEVY ONLY
Old 02-23-2014, 01:51 AM   #17
mrolds88
Good deal, Chris!! Now that you have this figured out, look into the relay mod. Also the window that is slow, check the in door connections and do a re lube. Might do more wonders.
93 K2500 xcab 6.5TD
Old 02-23-2014, 01:52 AM   #18
cjlloyd81
cjlloyd81's Avatar
What relay mod?
Old 02-23-2014, 02:04 AM   #19
mrolds88
Here's 2 threads that should help you out.
http://67-72chevytrucks.com/vboard/s...t=window+relay
93 K2500 xcab 6.5TD
Old 02-23-2014, 04:17 AM   #20
cjlloyd81
cjlloyd81's Avatar
Originally Posted by joe231 View Post
Awesome!!!
Any pictures?
I don't have any right now, but tomorrow when I go back out to putz around I'll take some. It's like a pre-Avalance type design. Sectional, that removes to allow access to the in bed kingpin.
1966 Dorsett Daytona - 16'6" Fiberglass boat "Suits Us"
1972 Chevrolet P30 Motorhome - "Giddy Up Go"
1986 GMC C3500 High Sierra Custom - "Ruby"
2007 Chevrolet Avalanche - "Faith"
