02-23-2014, 11:11 AM | #1 |
Little help please
Picked up some aftermarket grille molding clips, and they are whooping my butt, does anyone have pics of them installed on the trim, or something showing how they are mounted.. Thanks
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=614365 68 & I'll Owe You 1 |
02-23-2014, 11:34 AM | #2 |
Re: Little help please
don't have pics but mine had like spring loaded clips with threaded like bolts that fit thru the oles in the grill then you put the nuts on
02-23-2014, 12:10 PM | #3 |
Right, but I'm not sure how the clips attatch to the molding
02-23-2014, 10:26 PM | #4 |
The Older Generation
I don't have any pictures but I had to re-bend the clips to make them work. If you have any of the original clips try to bend the new ones so they match the old ones.... LockDoc
02-23-2014, 11:02 PM | #5 |
Yeah the new ones dont quite have the same bend as the oe's
1967custom |
02-24-2014, 06:39 AM | #6 |
These molding grill clips are a real pain. Surprised someone hasn't came up with something a bit more user friendly to install over the years. Like you, I had sore fingers fighting these clips in place. Plus a few flew apart also from making them perform as I wanted. Wasn't a walk in the park and took me an afternoon of marking the trim to the correct spot was the biggest help (used small pieces of masking tape) and plenty of breaks in between. But stick with it, get all of the clips in the right spot in the molding first with the proper alignment. Try to get them as level in the molding as possible, once you bolt them up and you see a gap or something you will be disappointed and need to start over again.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
02-24-2014, 06:48 AM | #7 |
No pics during the install just this one after reinstalling the grill. Good luck.
02-24-2014, 08:00 AM | #8 |
I had same problem with the clips that came with m ... I got these from
Ebay and they worked great , no problems at all ... http://www.ebay.com/itm/NEW-67-68-Ch...3D271358317445
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD 70 CHEVY C/10 LWB x 2 ----- SOLD 67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN " Build thread : http://67-72chevytrucks.com/vboard/s...15#post6826315 |
02-24-2014, 08:05 AM | #9 |
Looking at the back of the molding the clips are installed with the spring side of the clip on the left , Fit the head of the "bolt" into the molding and using your right thumb push the "spring" end of the clip up and into the molding .
they are designed this way to fit into the molding easily so as when you are tightening the nuts the oblong head binds in the molding and doesn't turn also the spring keeps the "bolt" from moving around while installing the molding . As said before you can use thin pieces of masking tape to mark the correct position then install the clips and it should line right up less than 30 minutes to install both moldings . |
