Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Closed Thread
Old 02-13-2014, 11:36 AM   #1
Hart_Rod
Hart_Rod's Avatar
WTB Oil pressure sender adapter
I need an oil pressure adapter that bolts just above the oil filter. It's the type that needs to be drilled and threaded for an oil pressure sender.
Hart_Rod is offline
Old 02-13-2014, 08:57 PM   #2
SeTx67
SeTx67's Avatar
Re: WTB Oil pressure sender adapter
http://www.improvedracing.com/oiling...d7cc2e7286eedb
SeTx67 is offline
Old 02-13-2014, 09:05 PM   #3
SeTx67
SeTx67's Avatar
Here's some other info with part numbers that may give you some other options/ideas
http://www.ls2.com/forums/showthread...r-on-LS-Series
SeTx67 is offline
Old 02-14-2014, 06:51 PM   #4
Hart_Rod
Hart_Rod's Avatar
Thanks for the info. I was just hoping someone had an extra one laying around. I do somewhere, but I just can't find it!
Hart_Rod is offline
Old 02-24-2014, 11:31 AM   #5
ls1nova71
ls1nova71's Avatar
You still need one of these? I'm sure I have some lying around.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline
Old 02-24-2014, 11:54 AM   #6
Hart_Rod
Hart_Rod's Avatar
Whatya got?!
Hart_Rod is offline
Old 02-24-2014, 08:44 PM   #7
ls1nova71
ls1nova71's Avatar
Originally Posted by Hart_Rod View Post
Whatya got?!
I got one of them there $28 block off plates. Id take $26.50 for it.
Seriously though, I'd do $5 shipped on it.
Old 02-25-2014, 11:28 AM   #8
Hart_Rod
Hart_Rod's Avatar
Thanks! Send me your paypal!
Hart_Rod is offline
Old 03-03-2014, 12:01 PM   #9
Hart_Rod
Hart_Rod's Avatar
Got it! thanks!
Rob
Hart_Rod is offline
Old 03-03-2014, 01:19 PM   #10
truckdude239
truckdude239's Avatar
i bought one from my local dealer came off a gto was already threaded and used the autometter 2277 adpator to mount my sensor
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
truckdude239 is offline
Old 03-12-2014, 01:14 AM   #11
Motoxrrar
They are pretty easy to thread just drill a hole and a cheap tap will do the job.
I took mine off the original sender and tapped in with a t that is sold on ebay, mainly because I have an oil cooler on mine.
Motoxrrar is offline
Old 03-12-2014, 09:38 PM   #12
First c10
First c10's Avatar
Can I ask why you can't put the sender were the original sender was for the lsx?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline
Old 03-12-2014, 10:09 PM   #13
Motoxrrar
It depends on the motor you have I suppose. I have a 4.8 LY2 and the original oil pressure sender is needed to run the motor for E38 pcm's. But I just tapped a whole underneath it like a "T" and hooked my line to my gauge. That way I can run my original gauges in my truck.
Also my coolant temp gauge I used a sender from a 86 Monte Carlo ss and cut the threads down with my lathe to fit in the passenger side of the head. Didn't want to be cutting too many wholes into the heads or using those big donkey adapters that stick out of the block.
Tach is easy to run off the pcm or msd makes a tach signal adapter that clips onto the coil wire too..
I do have a block off plate too except it's not tapped yet.
Old 03-12-2014, 11:28 PM   #14
First c10
First c10's Avatar
Ok cool. I m trying to get the oil pressure through my vhx gauges via the can bus
GO GO!!!
Old 03-12-2014, 11:41 PM   #15
Motoxrrar
Lightbulb Re: WTB Oil pressure sender adapter
That should be fairly simple.
Dakota digital gives you pretty much all the adapters you might need including the sensors you need. Only one thing I could imagine you might have is where to put the sensors.
Did you find a location to put your water, oil, and vss already?
Old 03-13-2014, 01:38 AM   #16
First c10
First c10's Avatar
I have all the parameters from the obd2/canbus except the oil. DD said that it won't read it. But I read somewhere that it was possible.
GO GO!!!
Old 03-13-2014, 01:48 AM   #17
Motoxrrar
What motor do you have ? And what pcm are you using?
Old 03-13-2014, 01:51 AM   #18
First c10
First c10's Avatar
2011 lc9/6L80 e38 ECM
GO GO!!!
Old 03-13-2014, 02:00 AM   #19
Motoxrrar
I could have swore there is a signal from the pcm on the e38.
I'll do some checking Monday with a friend of mine and find out for you.
Do you know what the signal parameters are required by DD?
Old 03-13-2014, 02:08 AM   #20
First c10
First c10's Avatar
I am not sure. As I don't have anyway to know except what the dd reads when I plugged it in. But thank you for the information it would be nice to get all the info to the Vhx gauges. I can get the mechanics and the electric parts working this communications part I am not sure about.
GO GO!!!
Old 03-13-2014, 02:13 AM   #21
Motoxrrar
No problem probably Monday I'll see my friends at ProDyno of Phoenix. One of the owners has a 70 chevy with a DD dash and turbo 5.3l I'm sure he will have the answer for sure. I will get back to you then.
Old 03-13-2014, 02:15 AM   #22
First c10
First c10's Avatar
Thanks for the help.
GO GO!!!
Old 03-13-2014, 08:12 AM   #23
Hart_Rod
Hart_Rod's Avatar
The E38 computer does push an oil signal of the CANBUS, however, Dakota Digital's BIM-01-1 will not display it on the gauges. I'm not sure why and I've spent about 3 months and written numerous emails back and forth with DD and received no good reason why their BIM won't display it. I get IAT, gear indication, H20 temp, speed, tach, trans temp and OAT (if you have the sensor) but no oil pressure..... I let them know that most of the other gauges out there that use the CanBus CAN display oil pressure, so hopefully my continual bugging about this will prompt them to updgrade their BIM interface.
Hart_Rod is offline
Old 03-13-2014, 01:53 PM   #24
First c10
First c10's Avatar
I hope we can figure it out. So until than I guess I need to put the sender that came with the gauges. In combination with the stock one.
GO GO!!!
Old 03-13-2014, 01:58 PM   #25
Motoxrrar
I think that's a 1/8 NPT that came with it right? Where will you put it?
Closed Thread
