Old 02-25-2014, 07:38 PM   #26
mmiddle
mmiddle's Avatar
Re: drilled hole in transmission
Originally Posted by solidaxel View Post
Mercy, what did you use to cut the floor sheet metal?
Portable cordless Beaver?
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 02-25-2014, 07:48 PM   #27
terry b
terry b's Avatar
Looks like you got a handle on it. I had no idea the floor was so close to the trans. Good luck with the repair.
terry b is offline   Reply With Quote
Old 02-25-2014, 09:05 PM   #28
elf w/capital T
Originally Posted by pwdcougar View Post
Screw in a short bolt or screw with teflon tape?
elf w/capital T is offline   Reply With Quote
Old 02-25-2014, 09:10 PM   #29
JCD
JCD's Avatar
Cheap easy fix for you is the JB weld, but here's a tip..
Take the drill bit you used, and cut a small piece the width of a dime off the top of the drill rod.
Put that "disc" of metal into the hole you drilled, it won't fall through, and will cap the hole so the JB weld doesn't ooze through the hole as it sets..
Scuffing up the metal around the hole and cleaning it with acetone would be a good idea as well.
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 02-25-2014, 09:25 PM   #30
lousyflyer
Holy Floorboard, Batman!
lousyflyer is offline   Reply With Quote
Old 02-25-2014, 11:57 PM   #31
ItsRandy
ItsRandy's Avatar
J.
He's in Norway...tell him how thick a "dime" is.
ItsRandy is offline   Reply With Quote
Old 02-28-2014, 12:39 PM   #32
BluTrukker
BOHICA
BluTrukker's Avatar
Did the sealant work?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 02-28-2014, 05:46 PM   #33
lousyflyer
I am very curious to know if the repair was a success.
Old 03-02-2014, 12:45 AM   #34
motorcritter
motorcritter's Avatar
1 US dime = 1 mm. I keep one in my tool tray- to set spark gaps on Japanese cars. Also, a US nickel weighs 5 grams. And, no, I'm not admitting anything else!
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 03-02-2014, 07:10 AM   #35
JCD
JCD's Avatar
I didn't want to say use a Krone, because in his case it wouldn't solve the problem.
J.
1971 Demon 340
1969 SS El Camino
Old 03-02-2014, 07:36 AM   #36
k29349
I think I would change the tranny fluid a few times after all this.
k29349 is offline   Reply With Quote
Old 03-02-2014, 07:44 AM   #37
Magnus-stepper
I put i little metal plate in there. Not a krone hehe. And sealing on the top, then it sat for 3-4 days and it worked 100% no leaks.
Thanks for the help !
Magnus-stepper is offline   Reply With Quote
