Old 02-25-2014, 07:39 PM   #1
1963c-10
1963c-10's Avatar
1963 SWB Fleetside bed bolt length needed
Need the length of the bed mounting bolts for a 63 short fleetside truck. Im a stepside guy and i know the fleetsides are different. Picking up the new 63 Saturday and need to get the bed bolted back down to transport. Just need the length and size....thanks in advance.
1964 Short bed trailer
Old 02-25-2014, 07:41 PM   #2
1963c-10
1963c-10's Avatar
Re: 1963 SWB Fleetside bed bolt length needed
I'm pretty sure they are probably 7/16 or 3/8 diameter. Ive looked through the FAQ's with no luck. Found a ton on the 67-72 board, but I know some of those beds were steel also.
Old 02-25-2014, 08:25 PM   #3
60-66
60-66's Avatar
This isn't going to help much but these are what they look like. These were from my 63 longbed. If no one answers I will pull one off tomorrow and measure.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-25-2014, 08:28 PM   #4
1963c-10
1963c-10's Avatar
I just need to pick up something to get it home (2hr drive). Won't be permanent, just a couple of carriage bolts I can pick up from home depot for the transport. I'll get the proper hardware when I get around to restoring it.
And thanks for the help.
Old 02-25-2014, 10:24 PM   #5
donthekawguy
donthekawguy's Avatar
A couple of 4 inch will work. Or you can get a couple of 5 inch to make sure
66 shorty
donthekawguy is offline   Reply With Quote
Old 02-25-2014, 11:45 PM   #6
1963c-10
1963c-10's Avatar
ok, thanks. i'll get some 3/8" x 4.5" then
