Old 02-26-2014, 02:20 AM   #1
fastpace
Problems with Porterbuilt rear shock mount lining up
I've already sent these pictures to Travis at Pro Performance and he's talked with the guys at Porterbuilt and we're planning on mailing the lower shock mount back to Porterbuilt tomorrow to have them double check it in the jig. I just want to check and see if maybe someone on here recognizes maybe an issue somewhere else.
When going to install the rear shocks the angles of the top and lower shock mounts.
Right now the trailing arms are in the hole second from the bottom with the heims all the way in. The rear end is pretty well centered in the notch and the pinion is tilted up just a little from horizontal, visually it looks to be about the right angle and we're estimating our ride height. Here's a couple other pictures of the install:
Everything else has seemed to line up pretty good so far except for this one piece. Any suggestions?
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 02-26-2014, 03:01 AM   #2
sduckworth13
sduckworth13's Avatar
Re: Problems with Porterbuilt rear shock mount lining up
Here is link with a ton of pictures to compare your setup to.
http://67-72chevytrucks.com/vboard/s...d.php?t=406186
Scott
sduckworth13 is offline   Reply With Quote
Old 02-26-2014, 03:29 AM   #3
fastpace
Thanks that's a great link and after staring at all the pics for about 15 minutes I still can't figure it out.
Old 02-26-2014, 07:35 AM   #4
mac808
mac808's Avatar
Not sure if its just the angle of the camera but your axle looks a tad closer to the front of the truck than towards the back and not exactly centered in the notch.
Looks ok in the last pic though.
mac808 is offline   Reply With Quote
Old 02-26-2014, 07:37 AM   #5
mac808
mac808's Avatar
Maybe back off the threads on the trailing arm at the cross member to 'extend' the length of the arms so the axle can be centered...?
Old 02-26-2014, 07:50 AM   #6
PGSigns
PGSigns's Avatar
Not sure if this will help but here is what I noticed from the two sets of pictures. Yours does not have the bracket under the shock upper cross member that the one in the other pictures has. This may roll the bracket back and into a little better alignment. Also the other pics are of the system fully aired out and that will improve your angles also. If the design was done with the trailing arms in a lower hole the would more than likely line up just fine. All other positions will be a little off. If you plot the travel with the shock bolts facing forward and back you will find they are only parallel at one position. It's a little hard on the shock bushings but that is the price we pay for having a lot of options on ride height with an air ride system. I think if you ran it with the trailing arms in the lower holes for a low instant center with power plant you have the shock angles will be better and I think you will like the way the truck drives.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-26-2014, 12:01 PM   #7
fastpace
Jimmy
Yeah it's only going to line up perfectly in 1 spot, but you want that spot to be near your ride height. It's fine if the shocks are a little off when it's laid out because it's in a static position. Also if I put the trailing arms in the lowest hole then my pinion angle will be too low and the rearend will be sitting too far back.
When the rear is move up into the notch it sits pretty close to the center of the notch, if anything it sits a little back on the notch.
Old 02-26-2014, 01:00 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
Fastpace-
I didn't notice anything else that stands out as being a concern.
Do me a favor and simulate ride height to compare the tabs. It does look to be off a little more than desired in the pics.
I just want to compare it to the fixture that locates the tabs before we send another one out to ya. I apologize for the delay/inconvenience I just don't want to send you an identical bar if it isn't lining up on your set-up to begin with. By having it in hand we can make sure you get one that will work better than what you have.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-26-2014, 02:35 PM   #9
fastpace
Originally Posted by Porterbuilt Street Rods View Post
Fastpace-
Nate
Nate,
I think that picture should be close to ride height. That's basically the height of the bag as it naturally sits with no pressure and no weight on it and the axle tube sits probably 2 inches below the point that would be the bottom of the factory frame rail. I'll be honest I'm not really sure where ride height should be but by looking at and estimating from other peoples pictures I would think we're pretty close. Also, we're mounting the bag directly to the frame rail/notch so there's no cup or additional plate.
The lower mount is boxed up and Travis just sent me the shipping label so we'll probably get it sent out tomorrow. Thanks to both you and Travis for the customer service, both me and the shop doing the install were very happy with the fitment of everything.
Jared
Old 02-26-2014, 03:56 PM   #10
PGSigns
PGSigns's Avatar
The pinion is easily shimmed and if you lower the front it will bring the rear ever so slightly forward. You are going to want to match the pinion angle up once the engine is fully bolted in place.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-27-2014, 12:46 PM   #11
aggie91
I'm just glad to be here!
aggie91's Avatar
One thing I noticed in comparing the pictures, yours does not have the stud for the upper shock mount in place. that stud spaces the shock away from the mount about 1/2" rearward on the top. Its hard to tell in the pictures but does the lower use a stud mount too? If so, that would space the shock about 1/2" forward on the bottom too.
If those are installed, how well does the shock line up at ride height?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-27-2014, 12:52 PM   #12
PBFAB.COM
PBFAB.COM's Avatar
This missing brackets in question for the upper shock bar should not change its angle.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-27-2014, 01:10 PM   #13
aggie91
aggie91's Avatar
I was thinking the angle of the shock was the problem, not the angle of the stud mount. I see that in the picture now....
Karl
The LST Challenge:
