Old 02-27-2014, 08:28 AM   #1
jesdude7789
jesdude7789's Avatar
1987 gmc axle swap ??
Hey guys,
I am looking to swap the rear axle on my 87 gmc truck because it is a 2.73 ratio. Crappy I know, and it's my daily driver. I have been living with it for 6 years now and I'm thinking that it's time to get a better ratio in it. I found this axle on craigs and it's from a 1991 g20 chevy van that is a 3.42 ratio and I'm wondering if it is a direct bolt-in swap? Can anyone help me out? I tried finding an axle interchange list somewhere but haven't found anything yet. I'm not going to modify my suspension to make something work either.
thanks for any info
jesdude7789 is offline   Reply With Quote
Old 02-27-2014, 08:38 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: 1987 gmc axle swap ??
I'm not exactly sure - hopefully some other guys will chime in - but it should be close.
Keep in mind a "G20" is really the same as a "C10" with the 5 hole/5" bolt circle. G vans didn't get the 8 lug setup until the G30 series.
The only thing that might be different would be the positioning of the spring perches. If you jumped on this one and they weren't right it would still be a (relatively) easy fix.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-27-2014, 09:05 AM   #3
Katrina/10
Katrina/10's Avatar
It won't fit, van axles are wider than trucks.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 02-27-2014, 09:11 AM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
I'm fairly certain it is not a direct swap and fear the width is even different.
Have you tried looking on car-part.com for a local salvage with the rear end you want? I see several 3.42 rear ends that appear to be local to you. Remember, when buying stuff from these salvages, cash is king and they will negotiate usually.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 02-27-2014, 09:21 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Look for 87-91 Suburbans. A ton of them had 3.42 ratios.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-27-2014, 10:25 AM   #6
jesdude7789
thanks a lot. that will help for sure. I didn't know about that site.
What do you think is a reasonable price?
Old 02-27-2014, 10:46 AM   #7
nekkidhillbilly
you can use the gears in your axle.
nekkidhillbilly is offline   Reply With Quote
Old 02-27-2014, 11:02 AM   #8
jesdude7789
what are you talking about?
Old 02-27-2014, 11:04 AM   #9
nekkidhillbilly
if your truck is a 8.5 rear. you can take the gears out of the 91 8.5 and put them in your axle in your truck.
Old 02-27-2014, 11:09 AM   #10
jesdude7789
I can't be doing that. I don't have the special tools to rebuild an axle and this is my only vehicle that's drivable right now and it's my daily driver. I have to get a whole axle so I can swap it out on the weekend without any possibility of problems.
Old 02-27-2014, 11:13 AM   #11
RandyP
RandyP's Avatar
Complete axle swap is easy peasy stuff that any old do it yourselfer can accomplish. Swapping gears though, different story, different time zones and different planets usually.
I sell rear axle housing assemblies for $150 - $175 when I have them. So getting one from a licensed salvage yard I would guess $200. As I said though, ask about a "cash and carry" price. Hell maybe you'll at least get tax knocked off or something.
Another positive from buying at a salvage yard, you normally get a 30 day warranty. That gives you a few days to get the part installed and put a few miles on it to make sure it does not have issues. Whereas if you bought from a CL person, once you exchange the money for the part, it's all over.
Old 02-27-2014, 11:17 AM   #12
nekkidhillbilly
find somebody who can swap for you. shouldnt take more than a hour or 2. used axle your going to deal with bad bearings and all that, have to replumb your brakes. me id have a the gears swapped with a posi out of another 8.5. replace all the seals bearing and needle bearings while in there. you gotta think a used axle from 91 is going to have a whole bunch of miles and age on it and if a needle bearing goes you got to pull it apart anyhow. just my .02.
Old 02-27-2014, 12:01 PM   #13
jesdude7789
I did one years ago on my old 89 1/2 ton I used to have until my brother needed it. The stock 3.08 blew out on it one day and my dad got me a used 3.42 axle somehow or another and I swapped it out on a saturday. That gear combined with the holley tbi I had on it made it a good hauler for sure. gas mileage was in the toilet though haha. I am keeping the stock tbi on my 87 so I should be okay.
I wish I knew guys like that but I don't. Any local shop won't do anything but a full rebuild for around $1000 so that's out of the question. I need to get more gearhead friends haha
Old 02-27-2014, 03:53 PM   #14
Houston Ben
Houston Ben's Avatar
Hey, another square in my town! I was looking at that exact van a while ago thinking the same thing!! lol
Houston Ben is offline   Reply With Quote
Old 02-27-2014, 07:57 PM   #15
nekkidhillbilly
yeah i know some guys that can do it for like 200 or so plus parts. i wonder if you would best to buy the tools and do it yourself.
Old 02-28-2014, 08:47 AM   #16
Keith Seymore
Dang. Sorry bout that.
Didn't mean to lead the OP astray.
K
1979-1986
1986 - 2019
Old 03-03-2014, 02:46 AM   #17
kape
kape's Avatar
Hello, I swapped the g20 axle on my c10.
G20 axle is 1.968 inch wider on both sides than c10 8.5" rear and. Measured to bearing to bearing.
What i did , narrowed g20 rear end to 5 cm (1.968 inch) on both side. And then i used the old drive shaft. (28 splines.) and cut off all leafspring and shocks supports and relocated them like a original c10. works fine.
kape is offline   Reply With Quote
Old 03-03-2014, 03:30 AM   #18
andrewmp6
If the used rear end is in good shape its cheaper to swap then rebuild what hes got with different gears.
